Please help with server c220 m3 , Im done !!!
nomoreyou
i have 2 hard disks 3 tb for each , i tried to install windows server 2012 for one week till now i cant do it , i tried UEFI , i made UEFI windows and convert the hard disk to gpt when the installation is done , i cant boot , i tried to fix bcdboot and bcdedit and doesnt help . i read that is somthing related with the south bridge but when i enter the bios i found just enabled and disabled .
so please someone help
Walter Dey
Is this a standalone C220 ?
Have a look at http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
and verify your Version settings
W2012 or W2012 R2
Which I/O adaptor ?
7 Replies 7
Walter Dey
W2012 or W2012 R2
Which I/O adaptor ?
nomoreyou
i tried it i have 1.5(1)b ucs and i cant found it, and UCSC 220 M3l , W2012
what do you mean you have 1.5(1)b ?
to my knowledge this doesn't exist .
Can you provide overview what you are trying to do ?
What errors are you getting ?
Have a look at this
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C220/install/C220/raid.html#37150
thank you for your replay,
i tried to install windows server 2012 r2 on c220 m3 server but UEFI copy . i put myUEFi copy on usb and boot and convert the disk to gpt and after the installation complete , i couldnt find the windows and i cant boot from it . i enabled the UEFI from the Bios .
Are you using any raid controllers or raid setup ?
https://supportforums.cisco.com/discussion/11838546/ucs-c22-m3-software-raid-lsi-problem-hard-drive
Have you contacted TAC?
i used Raid 1 Mirror .  i have two hardisks 3tb for each , so i convert the hard-disk to GPT and i have problem after the installation
nomoreyou
pleaase any one can help???
