Problems with 2.21d firmware package
ronald.nutter
In preparing for a SAN install in the next couple of weeks, I applied the latest updates using the infrastructure and server firmware packages to my UCS chassis.  The infrastructure upgrade/update applied without incident.  Cant say the same for the Server firmware update.  Applied 2.2(1d) package.
After the reboot  when finished with the Server Firmware package, I noticed several issues.
1) In UCSM, the chassis graphic is flagging errors on each of the blades on local disk #2 and the chassis with no explanation
2) In the faults tab, I see errors about missing drives 1 and 2 on blades 2 and 4.  These are flagged as severity info on each of the 4 error messages. Vmware ESXi is not showing any errors with not being able to talk to any drives on any of the blades
I have a case open with TAC on this already.  Wanted to see if any one else had noticed this issue.
Walter Dey
This has been discussed before, but not resolved, I think
https://supportforums.cisco.com/discussion/12039911/equipmentmissing-after-ucs-upgrade-22
