Rename hostname of CIMC - Nexus 1110
I know how to rename the hostname on CIMC gui. I just don't know if there will be impact when changing it. Do I also need to reboot for the changes to take effect? Are there other things do i need to do/check before and after renaming?
Kirk J
If you are just talking about the CIMC host name, and not the name defined at the VSA level,, then you can apply that, without rebooting the over all server.
I don't think that even requires a reboot of the CIMC.  If it did, you can still reboot the CIMC without impacting the VSA, VSBs (i.e. VSM/n1k).
If you had open SOL/ mgmt connections to the VSA via the CIMC, those might get reset, but again, no  impact to actual services/HA for the VSA.
Kirk...
Thanks for answering. Great help :D
