Secure erase when RAID Drive Group deleted?
kurejko
I have a question regarding the way WebBIOS utility erases RAID drive groups on UCS Server. In the documentation, I found this warning:
Caution If you choose Clear Configuration or New Configuration, all existing data in the configuration is deleted. Back up data that you want to keep before you choose a configuration type.
Under Choosing the Configuration with the Configuration Wizard at this link
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/raid/configuration/guide/RAID_GUIDE/MegaRAID.html#41190
I am interested in how does Clear Configuration delete the data on the disk. Is there some overwrite involved? Would you call it secure erase? Our IT Security team wants to make sure the data is securely erased from a server we are planning to use for a different purpose at another location.
Kirk J
Greetings.
Deleting the VDs does not 'scrub' the data.
I have actually helped customers who's raid controller failed, corrupting/deleting the VD metadata off the drives, recreate the same VD (exact same size, strip size, across same physical disks), but without choosing 'init', and they got their whole esxi server and datastores back completely intact.
There are some LSI/Avago utilities including StorCli, that can trigger something similar to what you are looking for although I doubt they are dod compliant
http://docs.avagotech.com/docs/12352476  StorCLI syntax guide
Below extracted from above avago doc:
storcli /cx[/ex]/sx start erase [simple|normal|thorough] [erasepatternA=<val1>] [erasepatternB=<val2>]
This command securely erases non-SED drives. The drive is written with erase patterns to ensure that the data is securely erased. You can use the following options with the start erase command:
Table 11
Drive Erase Command Options Options Value Range Description erase simple: Single pass, single pattern write normal: Three pass, three pattern write thorough: Nine pass, repeats the normal write 3 times Secure erase type. erasepatternA 8-bit value Erase pattern A to overwrite the data. erasepatternB 8-bit value Erase pattern B to overwrite the data.
Input example: storcli /c0/e25/s1 start erase thorough erasepatternA=10010011 erasepatternB=11110000
BTW, C0/e25/S1 : C0=controller 0 (the first controller, and usually the only one installed.  e25 is Enclosure #25, s1 is drive slot #1
If you have SED/Self Encrypting Drives, than a more secure/complete wipe is triggered with:
storcli /c0/e25/s1 secureerase
For example if you check the spec sheets of a C240M4 SFF , you have SED drive options that include:
Kirk...
Kirk J
Greetings.
Table 11
Kirk...
BrianSekleckiGE
Revisiting this:  The best way to securely erase local non-SED SSD/HDDs in compliance with [ DoD 5220.22-M ] standard is to boot the DBAN ISO on the blade?  No way to instruct the UCSM policy or CIMC to perform this?
(This is a good way to nuke iSCSI, and FC/FCoE LUNs as-well)
I mention it because , in the 10 years since the question was first asked, the Cisco FirePower 7K/8K chassis now supports the standard:
 https://www.cisco.com/c/en/us/td/docs/security/firepower/hw/firepower_device/firepower_7k8k_device/scrub_hard_drive.html
I don't know about the FirePower 7000 or 8000, but the 9000 is effectively just a pre-bundled UCS Chassis.
And also IOS-XE platforms and appliances with local storage:
IOS-XE# factory-reset all-secure 3-pass-DoD 5220-22-M
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fundamentals/command/cf_command_ref/F_through_K.html
Yes. Use DBAN. (Or any other OS based disk scrubbing utility.)
The firepower scrub utility is built into the firepower OS and not a function of the underlying hardware/CIMC.
Servers connected to Intersight can use: https://intersight.com/help/saas/resources/secure_data_deletion
(Which essentially boots an OS to scrub the data.)
