Trouble logging into UCSM using local accounts on UCSM
johnsonld123
I believe I know what the issue is, native authentication is pointing to LDAP. However, I need a backdoor before making any changes to assure I am not locked out.
micturne
Level 4
Level 4
Hello Lee,
I saw that this was posted in the wrong section a while back so I moved it here when I discovered it.
Did you ever find a solution to your "backdoor challenge".  If so can you post your findings here.
sgangoly07
Hi Lee, Not sure if my response is relevant anymore. In case you have not resolved your issues, may i ask if you can logon via CLI without LDAP access? Following is a link which discusses general troubleshooting related to LDAP logging issues : http://www.cisco.com/en/US/docs/unified_computing/ucs/ts/guide/TS_GeneralTroubleshooting.html
Cheers- santanu
