UCS C220 M3 Memory DIMM 1333MHz & 1600MHz compatibility
navin_rk3
   I have UCS C220 M3 server with 2 x E5-2650v2 2.6GHz processor and 6 x 8GB DDR3 1333MHz.
Currently Cisco no longer ships this RAM so if I buy 10 x 8GB DDR3 1600MHz will it be compatible with existing DIMMs.
Naveen
Walter Dey
Hi Naveen
I assume your question is whether you can mix 1333Mhz and 1600Mhz Dimms ?
The answer is
For optimum performance, do not mix DIMMs with different frequencies. If you mix DIMM
frequencies, the system defaults to the lower frequency.
p20 of
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/C220M3_LFF_SpecSheet.pdf
Thanks Walter.
