04-21-2021 08:54 AM
Need to replace a CPU on a UCS C240 M4 server as per https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C240M4/install/C240M4/replace.html#45480.
However, the CPU that was delivered doesn't have the CPU plastic frame.
So I'm not able to place it in the server.
This is the old CPU.
Can the CPU be removed from the bracket without damaging it.
Or which part should I order to make the CPU usable.
04-22-2021 02:58 PM - edited 04-22-2021 04:56 PM
The M5s have a carrier called CPU Carrier: UCS-M5-CPU-CAR=, but I don't recall anything similar for the M4s.
The CPUs always came in a carrier, so if you sourced a CPU outside of the normal channels, you may not have too many options.
Does it look like the existing M4 CPU will come out of it's carrier?
Kirk...
04-22-2021 09:45 PM
Hello Kirk,
This is the CPU as received.(Pic below)-No plastic frame.
The part number is UCS-CPU-E52620D-RF
04-23-2021 05:59 AM
On this "Does it look like the existing M4 CPU will come out of it's carrier?"
Were you asking whether could be removed from the carrier. I had attempted to, but with on success.
Is there a guide to the removal of it & reinstall.
04-23-2021 09:31 AM
Those CPUs were always sold with the carrier/frame in place, so there was never a need to source the plastic carrier, and as such, no process defined to remove or replace them.
Sorry, can't be of more help...
Kirk...
04-26-2021 06:20 AM
Hi Kirk,
Would it be posible to install the CPU in the socket without the plastic frame/carrier?
04-26-2021 06:50 AM
I recall having run across a forum question for HP DL series server, where a customer had exact same question, and managed to remove the processor, and carefully aligned the bare CPU in the sytemboard slot.
Please keep in mind I would not try this on a in-warranty server (i.e. you don't have anything to loose, and server wouldn't work otherwise)
Gotta throw the disclaimer out there, that this is definitely not a Cisco TAC/Support condoned process 😉
Kirk...
01-09-2024 05:34 PM
Hey Josh
Were you able to install the new CPUs without the plastic frame? I'm in the same situation.
04-05-2024 12:28 PM
I have two spare carriers, let me know if anyone wants them.
