UCS Central Hierarchy Flow
douglascarson
Hi Guys,
I am starting to play with UCS central and understand the Domain Group Hierarchy flow.
I have configured one DG called test within UCS central.
I configured the DG root LDAP setting within operationals Management and expected to see this flow down to the UCS PE i registered within the test DG.
It looks like if i set the setting within the test DG directly the PE will pick up the setting.
So i guess my question show i expect to see the DG root setting being applied to the test registered UCS PE?
D
HI Douglas,
You'll need to make sure that you have opted for Global Policy Control of User Management from the local domain first (see below).
Hope this helps,
  -Jeff
HI Douglas,
Hope this helps,
  -Jeff
Hi Jeff,
I have all the local UCSM settings set as per the screenshot.
Douglas
