UCS Director, problem add UCS Serie-C
I have problem with UCS Director 5.0, the problem ocurr at the moment add the server UCS C200 M3, the error is as follows, the version of CIMC is 2.0(3d).
connectivity issues are discarded as UCS UCS Director & CIMC are within the same network, have been tested with different servers getting the same problem.
Thanks!
tei.cho01
Hi,Cristobal
Have a look at the Compatibility Matrix for Cisco UCS Director, Release 5.0
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-director/compatibility-matrix/5-0/UCSDirector-CompatibilityMatrix-50.html
It says that UCSD supports CIMC from 1.4 to 1.5.
So, try to upgrade UCSD to 5.2 or 5.3.
tei.cho01
Hi,Cristobal
