07-22-2016 10:25 AM - edited 03-01-2019 12:49 PM
Hello Friends
When I want to open the UCS Director through the web I always found this phrase "The system is starting up. Please wait until the system is ready." I wait for hourses and nothing happen 😞
Solved! Go to Solution.
12-06-2016 06:00 AM
07-25-2016 12:28 PM
I am having the same issue.. was it solved for you? If Yes, Please let me know how you get away with this issue.
12-06-2016 06:00 AM
can you please tell me the solution of this problem?
Thank you!
12-06-2016 06:13 AM
I just had to wait for 5 to 10 minutes and it is working. Restart of the services also was helpful sometimes.
I have installed UCSD in lab with very limited resources on VMware workstation.
11-21-2018 01:11 AM
I have now deployed UCSD 6.6 OVA 3 times on 2 different clusters in ESXi 6.5 and each time the VM fails to start. It appears to hang and has a small progress bar at the bottom of the console screen but no CPU activity. What is the solution?
