UCUpgrade Issue
conie saga
Hello all,
We have upgraded our Chasis & FI to latest to support IBM SAN V3700.
I use following files for upgrade:
ucs-k9-bundle-b-series.2.2.1d.B.bin
ucs-k9-bundle-infra.2.2.2c.A.bin
Upgrade went successful.
After upgrade completed, chasis is showing major alarm F0283: ether VIF 2041 on server 1/1 of switch A down.
Please check the attachments
I tried restarting the servers individual then whole chasis as well but alarm still there.
We dont have any OS installed into Blades its new installation.
Did any body faced same experience and what is solution for that ?
Manuel Velasco
Hi Coniesaga,
"We dont have any OS installed into Blades its new installation."
Since you don't have an OS installed this is an expected behavior.  Once you install the OS the faults will clear.
Please let me know if this helps.
Manuel Velasco
Hi Coniesaga,
Issue fixed once we install OS into baldes.
Conie
