Using OnBoard NICs with C240M5L hosts connected via FI.
DonTharrett
This may be an odd request. We have a vendor that insists they need direct connect copper network path between C240M5L standalone servers connected to FI switches and are configured through UCS Central. I have recommended just creating an additional vNIC and running the heartbeat through that interface.
It thought I would pose the question, to see if anyone is away of whether or not the on-board 10GB NICs, can be used inside UCSCentral as network interfaces. I don't see a provision in UCS Central, only vNICs.
Thanks and Regards,
Don Tharrett
amarino2
The LAN On Motherboard (LOM) ports are disabled when Integrated to UCS Manager.
The LOM ports on Cisco UCS C-Series Rack-Mount Servers integrated with Cisco UCS Manager can not be used for data traffic. The LOM ports are disabled when the C-Series Rack-Mount Servers are in Cisco UCS Manager mode.
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c-series_integration/ucsm3-1/b_C-Series-Integration_UCSM3-1/b_C-Series-Integration_UCSM3-1_chapter_01.html
You can install a non-VIC PCIe NIC and connect those to an external network. They are not managed by UCS Manager / Central but via the OS.
