VN-Tagging in Nexus 1000v
visitor68
Level 5
Level 5
VN-Link in hardware is implemented on UCS using the PALO adapter using VN-Tagging
Can the Nexus 1000v also tag traffic with a VN-Tag in the case where non-Cisco servers are used?
visitor68
Level 5
Level 5
C'mon, Cisco! This is a question about basic 1000v and VN-tag functionality.
Does the 1000v add a VN-Tag to achieve VN-link in hardware or is it ONLY a VIC card that can do it?
The use case I am thinking of is having the 1000v add the VN-Tag and then leveraging SR-IOV on a NON-CIsco adapter to map a vmnic to a VF, which in turn would be mapped to a vETH instance on the 5000/5500?
Here is some pertinent information from a Cisco document:
Deploying VN-Link with Network Interface Virtualization
In  addition to the distributed virtual switch model, which requires a  tight integration between the hypervisor, its management layer, and the  virtual networking components and implements switching in software  within the hypervisor, Cisco has developed a hardware approach based on  the concept of network interface virtualization. NIV completely removes  any switching function from the hypervisor and locates it in a hardware  network switch physically independent of the server. NIV still requires a  component on the host, called the interface virtualizer, that can be implemented either in software within the hypervisor or in hardware  within an interface virtualizer-capable adapter. The purpose of the  interface virtualizer is twofold:
•  For traffic going from the server to the network, the interface  virtualizer identifies the source vNIC and explicitly tags each of the  packets generated by that vNIC with a unique tag, also known as a  virtual network tag (VNTag).
•  For traffic received from the network, the interface virtualizer  removes the VNTag and directs the packet to the specified vNIC.
The  interface virtualizer never performs any local switching between  virtual machines. The switching process is completely decoupled from the  hypervisor, which brings networking of virtual machines to feature  parity with networking of physical devices.
The Nexus 1000v does NOT use VNTAG.
Louis
Then Cisco should update its documentation and make that point a lot clearer.
