What load balancing mode to use with B200M4 and OEL6?
Emorozov
Hello.
We have some B200M4 servers connected to 2xFI6248. Both FI6248 are connected to 2xNexus 5548 via 2 vPCs. vPCs are in trunk mode with access to couple of VLANs.
B200M4 server profiles contains 2 vNICs each virtually connected to separate FI.
I've installed Oracle Linux 6 (which is like redhat 6) and not sure what balancing method to use for bonding. AFAIK there is 6 of them:
http://stackoverflow.com/questions/20975828/bonding-on-redhat-6-with-lacp
! Please advice.
padramas
Hello Evgenly,
Hopefully, you figured out the answer by this time.
Only active-backup ( mode 1 ) is supported on servers managed by UCSM / FI
https://www.kernel.org/doc/Documentation/networking/bonding.txt
For baremetal OS, it is recommended to use Fabric Failover feature in UCSM ( UCS handles NIC redundancy ).
It also eliminates configuration requirement from OS as only one NIC interface is visible to it.
Padma
