WWPN not visible for newly added vHBA's on MDS.
gautam.verma1
Hi Folks,
Need some assistance here.
We are trying to connect our existing blades to a new Storage(EMC VNX).
We are running UCS B230 M2 blades and topology is below.
                vHBA1 __ FI's(port fc2/1,fc2/2) > Connected to Brocade switch and these switches are connected to CX4-120 Storage
                vHBA2
 Blade -
                vHBA3 __ FI's(port fc2/3,fc2/4) > Connecting to MDS(9148) new VNX 5400 Storage via port Channel
                vHBA4
vHBA3, vHBA4 are newly connected.
Now i want to do zoning on MDS for these 2 new vHBA adapters but when i run "show flogi database' command on MDS, I'm unable to see
WWPN for these 2 vHBA adapters. Though WWPN for a port channel is visible in output of this command. I want to know if i need to do zoning
by using WWPN of this port channel?
Walter Dey
I assume you created a service profiles, with vhba1-4 ?
Q. in which vsan's are this vhba's ?
Q. which pwwn / nwwn do this vhba's have ? btw. this are the pwwn which show up in the flogi database, and which are used for zoning.
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/whitepaper_C07-730016.pdf
http://community.brocade.com/t5/Fibre-Channel-SAN/Cisco-UCS-and-Brocade-config/td-p/31435
