beveritt
To ensure the correct installation process is being followed for Cisco Compute Hyperconverged with Nutanix, please refer to the following flowchart to choose the correct documentation for the system being installed:
This document covers the IMM deployment method.
To access the UMM deployment field guide, click here.
To access the ISM deployment filed guide click here.
A Field Guide covering the installation and initial configuration of Cisco Compute Hyperconverged with Nutanix systems using Intersight Managed Mode for Cisco UCS X-Series modular blade servers and C-series rackmount servers. Intersight Managed Mode (IMM) is the term for X-series and C-series servers connected to Cisco UCS Fabric Interconnects, which are managed entirely via Cisco Intersight. This guide is intended for technical training and educational purposes, for all who wish to install Nutanix on Cisco UCS based hardware following our supported hardware and software integrations and compatibility lists.
As a reference guide, the document presents our best practices and recommendations as of the time of publishing, and will be updated periodically. Please refer to the document history at the beginning to ensure you are using the most current version available.
The most recent revision, v1.2 added information covering IMM for C-series servers, plus additional information regarding role-based access control (RBAC) in Cisco Intersight, how to configure the Fabric Interconnects using Express Setup, and a few other minor improvements. Additionally, our guides are being renamed to help provide consistent naming related to the management modes used in each document.
The first revision, v1.1 added information regarding migrating the Cisco Intersight Appliance from ESXi to AHV when it is used during greenfield deployments. Also added is information regarding the Cisco Intersight Device Connector for Prism Central, enabling inventory, monitoring and alerting of Nutanix clusters within Cisco Intersight. There are numerous other improvements to the document flow, updated screenshots, additional information for troubleshooting and network connectivity requirements, and dozens of edits for additional clarity.
jomebrew
Hi beveritt.  I've been following your guide (with a consultant) and I've run into an issue deploying a new, greenfield instance with Intersight Managed Fabric Interconnect and M7 C220 in a Nutanix AHV deployment. We are trying to use the native VLAN (VLAN 1) for all networking including the CVM and Hypervisor. There seems to be an issue with how the deployment software and the FIs are handling VLAN 1. Once the CVMs are booted to Phoenix, we cannot ping any address including the other CVMs, host, router.
Are you aware of a requirement where the CVM, Hosts, CICM, etc must be on a tagged VLAN?
Thank you..
beveritt
Hello jomebrew,
All traffic in an IMM deployment will be tagged with a VLAN ID leaving the hypervisor and controller VMs, so using VLAN 1 as a native VLAN can cause problems. In general we don't recommend using VLAN ID 1 and to avoid setting a native VLAN in UCS whenever possible. Please see the following document regarding troubleshooting native VLAN issues you can see in UCS and Intersight: https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/intersight/222913-troubleshoot-native-vlan-issues-on-inter.html
