nashivar
Community Member
Steps to Upgrade from 1.4.6d to 1.5.4-3 using USB
Requirements:
- USB stick
- HUU image
- Standalone C-Series HUU Image (to be written)
Tool usage:
Linux Live USB creator
Steps:
  1. We have to use Linux Live USB creator to create bootable USB to upgrade  from 1.4.6d to 1.5.4-3
  2. Format the USB to FAT32 file system
  3. The USB creator exe file can be downloaded from http://www.linuxliveusb.com/en/download
    Download and install the exe file.
  4. Downloaded 1.5.4-3 HUU from Cisco.com and keep it ready.
  5. Procedure to make the USB bootable is present in the link http://www.linuxliveusb.com/en/help/guide/preparation
  6. Plugged the USB to server and reboot the server
  7. Press F6 during the server boot up and enter the boot menu options.
  8. Select the USB from the list of devices
  9. And the USB boots to the HUU and select “Update all”
