Greg Wilkinson
Cisco UCS Non Interactive Diagnostic Tool
You can use diagnostics tools to diagnose hardware problems with your Cisco servers. The user interface displays the status of the test run and examines log files for troubleshooting hardware issues. UCS Server Configuration Utility (SCU) provides is an application that provides Graphical User Interface for running Snapshot diagnostics tests on a standalone Cisco C-Series server.
With NI-IOD python script, user can run the same snapshot diagnostics tests on multiple C-Series servers. The script can be run from any Linux box with any version of python that supports multiprocessing.
The snapshot test results are copied to configured remote host
Download SCU ISO from cisco.com
Server Configuration Utility (SCU) iso is available at cisco.com for download
Download the latest version of iso. Although SCU is not dependent on server model, select UCS C240M4 and download SCU from that page.
Prepare the tool
After downloading the iso save it to share location. This can be a cifs/nfs/http share.
Copy the diagnostic tool to a linux server where you want to run the script
How to run the tool
Now configure the multiserver_config file with the address information of the server where you want to run diagnostic tool. Please check Appendix A for sample of multiserver_config file. Once multiserver_config file is ready, please use the below cli to run the tool. The "-l" option is not required, but useful if you'd like to log results.
How to check if tool is running properly
Once diagnostic tool kicks in, this will boot the server with diagnostic ISO and you will see below screen if you log into KV console of the server.
Once the server boot with SCU iso, the below screen will show up. Please don’t click on anything. The diagnostic tool is running in background.
You might see something similar like below while test is running. Again please don’t click on anything. You may even close the KVM console.
How to check the Results
Once the test finishes, the script reboots the server and a log file will be created on the remote server based on your configuration. The name of the log file is combination of server model, Serial number, date and time.
Appendix B has the sample results file
Appendix A
Sample Config file (multiserver_config)
Appendix B
Start of snapshot data. Time: Wed Feb 24 19:25:08 EST 2016
Server Inventory
Chassis/Baseboard summary:
Manufacturer: Cisco Systems Product ID: UCSC-C220-M4L
Version: 74-12419-01
Serial Number: FCH1827V19W
Server UUID: 53B7B1C6-7B47-4939-9080-125D01AEBF22
Number Of PSU: 2 Number Of Processors: 2 Total Memory: 32768 MB
BIOS version: C220M4.2.0.9b.0
BIOS vendor: Cisco Systems, Inc. Number of PCI adapters: 2
CIMC summary:
Firmware Version: 2.0(10.126) Mac Address: f4:0f:1b:1e:b2:5c IP Address: 10.29.131.118
Processor summary:
Processor Socket: 1 (Core count: 18, Core enabled: 18), Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz Processor Socket: 2 (Core count: 18, Core enabled: 18), Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz
Memory summary:
Total Memory: 32768 MB DIMM populated: 4
DIMM 1: Locator: NODE 0 CHANNEL 0 DIMM 0, Size: 8192 MB, PartNumber: M393A1G40DB0-
CPB , Manufacturer: 0xCE00, SerialNumber: 01E90931
DIMM 2: Locator: NODE 0 CHANNEL 1 DIMM 0, Size: 8192 MB, PartNumber: M393A1G40DB0-
CPB , Manufacturer: 0xCE00, SerialNumber: 01E9084F
DIMM 3: Locator: NODE 1 CHANNEL 0 DIMM 0, Size: 8192 MB, PartNumber: M393A1G40DB0-
CPB , Manufacturer: 0xCE00, SerialNumber: 01E90859
DIMM 4: Locator: NODE 1 CHANNEL 1 DIMM 0, Size: 8192 MB, PartNumber: M393A1G40DB0-
CPB , Manufacturer: 0xCE00, SerialNumber: 01E9085C
Storage summary:
Controller 1: MegaRAID SAS-3 3108 [Invader], Type: RAID bus controller
Vendor: LSI Logic / Symbios Logic
Disk 1: Description: ST1000NM0001, Vendor: SEAGATE, Size: 931.512 GB, Type: SAS Disk 2: Description: ST1000NM0001, Vendor: SEAGATE, Size: 931.512 GB, Type: SAS
Controller 2: RAID, Type: Mass storage device
Vendor: Cypress
Disk 1: Description: trymirror, Vendor: CiscoVD, Size: 29.719238 GB, Type: SCSI Disk Controller 3: Cisco USB Composite Device-1, Type: Mass storage device
Vendor: Avocent
Disk 1: Description: , Vendor: , Size: , Type: DVD reader Disk 2: Description: , Vendor: , Size: , Type: SCSI Disk Disk 3: Description: , Vendor: , Size: , Type: SCSI Disk Disk 4: Description: , Vendor: , Size: , Type: DVD reader Disk 5: Description: , Vendor: , Size: , Type: SCSI Disk
Controller 4: Intel Corporation, Type: SATA controller
Vendor: Intel Corporation
PCI Adapter summary:
Total adapters: 2
Adapter 1: SlotID:HBA, Card: RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS-3 3108 [Invader] (rev 02)
Power supply summary:
Total power supply: 2
PSU 1: Name: PSU1, Manufacturer: Cisco Systems Inc, Part Number: 341-0591-01, Serial: LIT182008HP PSU 2: Name: PSU2, Manufacturer: NA, Part Number: NA, Serial: NA
Server Inventory SerialNo-PID Data
----------------------------------------------------------------------- 000000000c2,DIMM_A1   0xCE00,FCH1827V19W,UCSC-C220-M4L
000000000c2,DIMM_B1 0xCE00,FCH1827V19W,UCSC-C220-M4L
000000000c2,DIMM_E1   0xCE00,FCH1827V19W,UCSC-C220-M4L
000000000c2,DIMM_F1   0xCE00,FCH1827V19W,UCSC-C220-M4L
0002Z1N49NLQ,SEAGATE SAS DISK,FCH1827V19W,UCSC-C220-M4L
0002Z1N4BPJ1,SEAGATE SAS DISK,FCH1827V19W,UCSC-C220-M4L
012345678900,CiscoVD SCSI Disk DISK,FCH1827V19W,UCSC-C220-M4L NA, DVD reader DISK,FCH1827V19W,UCSC-C220-M4L
NA, SCSI Disk DISK,FCH1827V19W,UCSC-C220-M4L NA, SCSI Disk DISK,FCH1827V19W,UCSC-C220-M4L NA, DVD reader DISK,FCH1827V19W,UCSC-C220-M4L NA, SCSI Disk DISK,FCH1827V19W,UCSC-C220-M4L
LIT182008HP,UCSC-PSU1-770W,FCH1827V19W,UCSC-C220-M4L NA,NA,FCH1827V19W,UCSC-C220-M4L
xxxxxx,Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz,FCH1827V19W,UCSC-C220-M4L xxxxxx,Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz,FCH1827V19W,UCSC-C220-M4L xxxxxx,PCI  ADAPTER,FCH1827V19W,UCSC-C220-M4L
Server diagnostics Quick test results:
Test name
result
  1. 1. Processor Test
PASSED
  1. 2. Cache Validation Test
PASSED
  1. 3. Memory Test
PASSED
  1. 4. VDisk4 (quick)
PASSED
  1. 5. PDisk1 (quick)
PASSED
  1. 6. PDisk0 (quick)
PASSED
  1. 7. Video Memory Test
PASSED
  1. 8. Interface1 (selftest)
PASSED
  1. 9. Interface0 (selftest)
PASSED
  1. 10. Interface1 (linktest)
FAILED
  1. 11. Interface0 (linktest)
FAILED
  1. 12. QPI Link Test
PASSED
  1. 13. QPI Traffic Test
PASSED
  1. 14. CIMC Self Test
FAILED
  1. 15. LSI backup battery Test (ctrlId 0)
N/A
  1. 16. LSI RAID Adapter Test (ctrlId 0)
PASSED
  1. 17. Chipset Test
PASSED
  1. 18. Enclosure Test
N/A
Server Probe data
Faults:
  1. (CIMC) SEL fullness percentage: (100.00), sensor reading is critically high
Warnings:
  1. (PSU) PSU2 is not installed in the slot
End of snapshot. Time: Wed Feb 24 19:25:09 EST 2016
