on 04-29-2016 11:58 AM
Cisco UCS Platform Emulator, Release 3.1(1ePE1)
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
New Features and Significant Changes in Cisco UCS PE, Release 3.1(1ePE1)
New Platform Emulator GUI Features
New Hardware FeaturesSee the User Guide for additional details on supported Hardware. Here is a summary of M4 and 3rd Generation Fabric Interconnect Hardware:
Known Limitations
Backup/Import of UCSM Configuration
Firmware Management Note: UCS PE supports uploading B-Series, C-Series, and M-Series server firmware bundles. Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of stripped-down versions (link below). Stripped-down versions include only the firmware metadata (not the actual firmware binaries).
Download Note: If you have issues downloading the attached OVA or Zip file, please try the following cisco.box.com links:
MD5 sums for each download:
It looks like Java is not installed correctly on your machine. Can you try to re-install or change versions?
To confirm the problem is Java....attempt to launch the HTML5 GUI.
Hello Team,
I faced issue downloading the OVA/zip file. Therefore I downloaded the Box_Download_Links.txt.zip file.
I see there are two download links inside the Box_Download_Links.txt file.
See below:
To download the OVA or Zip files for UCS PE 3.1(1e), please use the following links:
UCS PE 3.1(1e) OVA file: https://cisco.box.com/s/u788fd8fs4epe3urqtegshhdqon104ei
UCS PE 3.1(1e) zip file: https://cisco.box.com/s/wxtlw1xkbxzzzoqwj7t3eh5tnx1ni0pl
Now, looks like link is broken or file is removed. I am getting below error for both the links:
Think it’s a mistake? No worries: Just email the owner or get in touch with Box support
. We’re here to help. Meantime, learn more about sharing files on Box – and other features, benefits and solutions – below.
What are options now ?
The box links had expired. I've posted the direct links in this document:
https://cisco.box.com/v/UCSPE-3-1-1e-ova
https://cisco.box.com/v/UCSPE-3-1-1e-zip
Also note that there is a more recent version of the emulator now available: Cisco UCS Platform Emulator 3.1(2ePE1)
Hi David!
What´s password (default) for user root? I need restore CentOS....
Restart my virtual machine UCS Emulator and in startup the CentOS show system with errors, check force /dev/mapper/vg_ucpse-lv_root:
I need the password (default) user root for I run fsck manually.
hello ,
im still facing this download problem , i tried many times , i changed the network provider but still not working
Do we have UCS 3.2 emulator? If not is it expected to be released in near future?
The 3.2 UCS Platform Emulator is not out yet, but we expect to release it later this year.
thanks David,you save me ![]()
Dear friends,I got a problem about download this UCS_PE 3.1.1 OVA File,please help!
I am able to see only 2 FI but none servers after deploying the ucspe, Secondly there are no emulator settings on the LHS of the webpage that we normally see in other versions. How can I add the servers in the chassis as there is no use if I cannot see any servers connected to chassis.
kvm console access is de-highlighted & Unable to ping IP's which are assigned to blades. please help me
KVM console access is not a supported feature on UCSPE. Blades and other hardware devices are emulated and there is no backing for network connectivity on those devices.
Let us know of other questions.
Thanks "David" for the clarification...
