on 03-13-2017 03:10 PM
Cisco UCS Platform Emulator, Release 3.1(2ePE1)
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
New Features and Significant Changes in Cisco UCS PE, Release 3.1(2ePE1)
Feature Summary of 3.1(2ePE1) based on previous release information:
Hardware Feature Summary
See the User Guide for additional details on supported Hardware. Here is a summary of newly supported Hardware:
Known Limitations
IMPORTANT CONFIGURATION NOTE: Backup/Import of UCSM Configuration
Firmware Management: UCS PE supports uploading B-Series and C-Series server firmware bundles. Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of stripped-down versions (link below). Stripped-down versions include only the firmware metadata (not the actual firmware binaries).
Alternate Download Location: If you have issues downloading the attached OVA or Zip file, please try the cisco.box.com links in the attached Box_Download_Links_3_1_2ePE1.txt.zip file.
MD5 hashes for downloads:
can not download completely both of the two method!!!
I cant download this file
This download does not work. The OVA file will only download 335.6 MB and is not complete. There is an issue with this file. I have tried with multiple computers and ISPs to rule out computer or network issues. Hopefully this will get fixed soon.
I can not download the OVA file. Please let me know if there another download link
thanks
Hi have downloaded both zip and ova OK.
Hi cannot download the files...
Constant Interruption, download resume also not supported. Unable to download since the last 36 hours,tried the cisco box links as well. Please fix this!!!
Here's a previous post with some possible fixes for download issues:
"I have seen this happen with various large downloads. I think what happens is that some cache server between you and Cisco's download site somehow ended up with a corrupted copy. No matter how many times you download, or what browser you use for downloading, you will continue to reach the same cache server and keep getting the same corrupted copy.
Solution for me and others has been to move to another site, maybe a coffee shop, or maybe just your neighbor's house if they have a different ISP. You find a different path to Cisco that bypasses the 'bad' cache server and you are okay."
I've just downloaded both ZIP and OVA from box and verified the files are good.
Hi guys,
two questions about UCSPE:
1) It's available NXOS shell?
Issue:
ucspe# connect nxos
sh: /isan/bin/vsh: No such file or directory
2) It's possible to integrate UCSPE with NXOS emulator (in Virl Nexus 7000 device)?
Best regards
For #1, NX-OS is not available on UCSPE.
For #2, UCSPE does not have the ability to connect to external devices so there is not integration with other emulators.
Let us know of other questions.
Thanks.
David Soper Hi,
I use UCSPE have a problem, when UCSPE & UCS-Central integrated , create pools, like uuid-pool, wwpn-pool, but on UCSPE cant use it, casue not have global-pool, just have manual-config, default-pool , cant choose global pool.
Best regards
This is known problem with the emulator.
You technically should see the Global Pools being referenced in the pull-down with UCSPE, but they do not appear.
There is no known work-around sat this time, as it’s a bug with the Emulator.
Matt
Matthew Faiello | UCS Technical Marketing Engineer | .:|:.:|:. Cisco Systems, Inc.
mfaiello@cisco.com<mailto:mfaiello@cisco.com>| Phone: 727-540-1432 | Twitter: @<https://twitter.com/mfaiello>mfaiello<https://twitter.com/mfaiello> LinkedIn: mfaiello<https://www.linkedin.com/in/mfaiello>
UCS Communities: http://communities.cisco.com/ucs
UCS Platform Emulator: http://communities.cisco.com/ucspe
UCS Developed Integrations: http://communities.cisco.com/ucsintegrations
Hope fix this bug
Thx for your response, Matt.
Best regards
Hi Matt,
This bug maybe or not the drop-down menu window is small, so cant display global-pool?
This is just my opinion .Hope it is helpful.
Best regards,
Tao
No problems with any of the downloads.
