11-05-2019 05:23 AM - edited 11-05-2019 06:02 AM
Cisco UCS Platform Emulator, Release 4.0(4ePE1)
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
New Features and Significant Changes in Cisco UCS PE, Release 4.0(4ePE1)
Hardware Feature Summary
Please see the Release Notes for a complete list of supported Hardware. Below is a summary:
Known Limitations
IMPORTANT CONFIGURATION NOTE: Backup/Import of UCSM Configuration
Firmware Management: UCSPE supports uploading B-Series and C-Series server firmware bundles. Because of the large file sizes of the firmware bundles, UCSPE only supports uploading of stripped-down versions (link below). Stripped-down versions include only the firmware metadata (not the actual firmware binaries).
Download Instructions
MD5 hashes for downloads:
Getting an error when trying to add a user.
ucspe /security/local-user # scope security
ucspe /security # create local-user ansible
ucspe /security/local-user* # set account-status active
ucspe /security/local-user* # set password
Enter a password:
Confirm the password:
Error: /isan/bin/sam_validate_password.sh: line 5: /bin/ssh: No such file or directory
Dear Admin Team,
Please help me out, i want to get rid off from rack-mount servers from my lab ucspe 4.0. i just remove the FEX but not able to remove the rack-mount servers which is already power off and all FI-A and FI-B Links are remove. I am a New Bee Here and Beginner for UCSPE. I am very thankful to if any one help me out to elaborate how to customize the lab or delete all the object and start on my own way. I am waiting for your quick and positive response..
I am facing the same issue creating new user
Enter a password:
The OVA and ZIP download is not available. Someone please fix it.
