on 05-26-2022 11:36 AM
Cisco UCS Platform Emulator, Release 4.2(2aPE1)
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
New Features and Significant Changes in Cisco UCS PE, Release 4.2(2aPE1)
Hardware Feature Summary
Known Limitations
IMPORTANT CONFIGURATION NOTE: Backup/Import of UCSM Configuration
Firmware Management: UCSPE supports uploading B-Series and C-Series server firmware bundles. Because of the large file sizes of the firmware bundles, UCSPE only supports uploading of stripped-down versions (link below). Stripped-down versions include only the firmware metadata (not the actual firmware binaries).
Download Instructions
MD5 hashes for downloads:
@dsoper Thanks for looking at it. Is this something that will be looked at for resolution in a future release?
Has the Emulator now been discontinued?
There doesn't appear to be any valid download links.
A new link has to be created now and then. Usually an admin will create a new link when someone mentions it here.
Thanks for the reply. I am logged on with my cisco.com account and I don't get any files being shown when I follow the link
When will UCSPE release 4.3 become available?
Is it still possible to download the emulator? The links lead to a page where you can't download anything.
Thanks for your reply. Unfortunately I still don't see anything on the download page. I have tried the following:
1.- Launch a Chrome browser in a private browser session.
2.- Login to the portal via https://id.cisco.com/
3.- Access the following link to download it:
https://software.cisco.com/download/beta/473431653
Is this the correct link for the download? I don't see any other.
