Matthew Faiello
The UCS Central Operations and Best Practice Guide helps administrators of single or multiple UCS management domains to aggregate and simplify management through UCS Central.
This version has been updated for the UCS Central 1.4(1a) Release.
This document is intended for administrators of multiple UCS management domains, and to help those administrators understand the utility, use-cases, and advanced design principles for adopting UCS Central with its centralized object repository, template and policy management. An experienced level of UCS Administration is assumed. This document is intended as an accompaniment, and not a replacement, for the UCS Central product reference guides and documentation.
simon.wright321
Very good read so far, once I have been able to deploy the medium scale I am sure I will have many questions, just wanted to say thanks for this and keep it up.
Simon.
