jasonsha
Level 5
Level 5
UCS Performance Manager v2.0.2 is now available!
Built with technology from ZENOSS, Cisco UCS Performance Manager (UCSPM) is an agent-less, performance monitoring and capacity planning tool custom built for the UCS Administrator.  UCSPM provides unified visibility into UCS infrastructure, LAN/SAN switching, storage arrays, hypervisors and server operating systems.
Maintenance Release:
This release is primarily a Maintenance Release and contains many defect fixes.
- This release is recommended for anyone using a prior version of UCSPM 1.x or 2.x.
New Features
  • Self Monitoring - UCSPM will automatically register and monitor the Control Center application.
  • Public Endpoints - the ability to to create a "public endpoint" for access to the UCS Performance Manager and Control Center application web servers directly via  ip : port.
This release also includes new additions to the Appliance Administration menu (allowing for menu driven execution of common tasks):
  • "Update System" provides a simplified update/upgrade process
  • "Reboot/Shutdown System"  easy access to reboot or graceful shutdown of the UCSPM Appliance
UCS Performance Manager v2.0.2 is a free upgrade for existing customers
  • Note:  UCSPM 1.1.x license files are compatible with UCSPM 2.x).
  • Note:  Existing Performance, Modeling and Event data can be migrated from UCSPM 1.x deployments to a UCSPM v2.0.2 instance.
UCSPM v2.0.2 contains a built-in 30-day eval - Download from Cisco.com today:
Download UCSPM Software today:
- Software
Documentation:
- Release Notes
- Install and Getting Started Guides
- Migration Guide
- Admin Guide
- User Guide
Deployment Calculator:
UCSPM 2.0 Deployment Calculator
(Highly Recommended  - identify VM requirements prior to deployment)
UCS Performance Manager 2.x JSON API Documentation (attached)
