ericwill
UCS PE supports uploading B-Series and C-Series server firmware bundles.  Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of stripped-down versions with only the firmware metadata (not the actual firmware binary).  The stripped-down versions of the firmware bundles for various B-Series and C-Series servers are attached below.
ericwill
I have not been able to reproduce this.  I performed a local upload from my local filesystem, and got it to upload successfully.  Why are you specifying "image.txt" at the end?  What process are you trying to upload this with?
Eric
venkatevt
I am following the normal process like going to firmware management tab and click on download firmware and selected the files which i downloaded from site, when i am at like 98% i get this error message
ericwill
Can you reach out to me directly, and provide more details.  My email is ericwill at cisco.com.  Maybe we can do a WebEx session.
vediga
Community Member
can you please let me know your webx id or cisco id...i can share my desktop via jabber..
ericwill
My cisco / jabber / email id is ericwill at cisco.com.
venkatevt
Thank you Eric for the support
ericwill
What version of UCSPE are you trying to import these firmware bundles into?  Is the error you are having on 2.2.1b, or previous?  The firmware bundles are only importable on 2.2.1b and beyond.
pepepopo74
Community Member
Sorry for the late reply. I was using an older version of the emulator. I've downloaded the newer one and it is working fine. Thanks Eric!
brian-s
Community Member
There's two slashes in the path after the server name....that's not a valid URL.
mvpratapvarma
Community Member
hi im trying to download ucs manger  from cisco site but im not able figure it out to download which series i downloaded ucs rackmount servers c series but im not able to install in my windows 8 pc am i need any software to install that image file
shasridh
Hi Varma,
Please use the below link to download the latest version of UCSPE.
UCS Platform Emulator Downloads (latest: UCSPE 2.2(2cPE1))
After downloading the image, you can either deploy it on a Hypervisor such as Vmware ESXi or Microsoft Hyper-v.
On Windows 8, you can use Vmware Vmplayer or Workstation
For Launching Cisco UCS Platform Emulator Using VMware Workstation on Microsoft Windows, please follow the below steps:
  • You can directly import an .ova file into VMware Workstation 8.
  • From the File menu on the VMware Workstation 8 menu bar, select Open.
  • Browse to the .ovf or .ova file and click Open.
  • Type a name for the virtual machine, browse to the directory for the virtual machine files, and click Import.
For more info on deploying the image on different platforms, please refer the User Guide available in the above link.
Sharan Sridhar
jweier
Community Member
Do you know if/when 2.2(6g) will be available? I'm trying to dry-run an upgrade.
Thanks!
Matthew Crocker
Is anyone else having problems downloading 3.1(1e) B-Series and C-Series firmware to the PE? Tried using both the HTML5 and Java apps with both IE and Chrome. Only when using the Java app do I see the task fails at 40% unpacking with an unspecified message in the event tab.
dsoper
Hi Matthew,
We have an upcoming release that resolves some issues with FW update on the PE. I'll send an update with new bundles when we release. -David
Matthew Crocker
Thanks for the prompt reply. Will sit tight for now.
