¿Hola como estás?
Quisiera saber la  compatibilidad de la PSU UCSB-PSU-2500ACPL, con un Cisco UCS 5108 -AC2
Steven Tardy
The PSU UCSB-PSU-2500ACPL is no longer listed on the Chassis spec sheet:
The PSU UCSB-PSU-2500ACPL EoL announcement:
The spec sheet should really include a "no longer purchasable but will function or not function section" to answer these questions.
The Wayback Machine has a copy of the old Chassis spec sheet which does provide details of the old PSU.
UCSB-PSU-2500ACPL Looks to be 220 VAC whereas the replacement UCSB-PSU-2500ACDV is 220 or 110 VAC.
Officially since UCSB-PSU-2500ACPL is no longer on the spec sheet, I think we must conclude it is not compatible.
The UCS Power calculator (http://ucspowercalc.cisco.com) also does not allow selecting UCSB-PSU-2500ACPL PSU with 5108 Blade Chassis (AC) V2 Chassis.
Jennings
The last-possible ship date that can be requested of Cisco and/or its contract manufacturers. Actual ship date is dependent on lead time.
Teco Login
