We found the software and installed it. But you feel it coming, i think there is more to it in SCVMM2012R2. The plugin installs correctly but there should be a setup afterwards that is not appearing. Furthermore you see the installed plugin in scvmm2012r2 but we cannot see the switch extension under the fabric network components. Is there a way to do it manually?
Furthermore if you add a network service and go trhough the wizard you cannot connect to the UCSM. The documentation state that you can use the ip address but the connection keeps failing. It doesn't matter if you use the ucsm admin account or the connected AD account.
Firstly, this isn’t supported on SCVMM2012R2. It is only supported in SP1.
Secondly, did you go thru all the steps as demonstrated in the video?
After you’ve installed the setup, there should be a new UCSM configuration provider appearing in the “Settings” tab.
Once you’ve done this you can create a new VSEM instance by selecting the right Configuration Provider from the drop down and filling in the IP and credentials.
One way to debug connectivity is trying to run the UCS PowerTool on the same server and connecting to the UCS Manager instance. If that fails, you have a bigger problem and should start with a “ping test”.
