Adding connections to UCS Fabric Interconnects
gcook0001
We are looking at adding additional connections between our UCS 6248UPs and our catalyst CS3850s.
Currently we have the following
FI-A to primary cs3850
FI-B to secondary cs3850
We would like to add
FI-A to secondary cs3850
FI-B to primary cs3850
From what I understand the configurations are as follows
FI-A and FI-B
add an additional Uplink port on each
cs3850
current connection
interface TenGigabitEthernet1/1/3
description "TRUNK to UCS"
switchport trunk allowed vlan 1,2,3
switchport mode trunk
spanning-tree portfast trunk
new connection
interface TenGigabitEthernet1/1/4
spanning-tree is configured on the switches as follows
primary
spanning-tree mst configuration
 name Region1
 revision 10
 instance 1 vlan 1
 instance 2 vlan 2
 instance 3 vlan 3
spanning-tree mst 0-3 priority 0
secondary
 name Region1
 revision 10
 instance 1 vlan 1
 instance 2 vlan 2
 instance 3 vlan 3
spanning-tree mst 0-3 priority 8192
From what I understand this should work.  If there is something I am missing please let me know.
I have attached a diagram for clarrification
Thanks Gordon
Kirk J
Greetings.
Had you considered putting the 3850's in a stackwise config?
You could cut down on the trunk interfaces between the two switches, and could also do port-channels from Each FI to a pair of ports (one on each stack member) which would have faster lacp port fail-over redundancy reaction, and better lacp load balancing.
If you are sticking to the dual physical/logical switch pair, then what you have looks fine.
The port-fast is correct for FI switching in end-host mode.
The MST related should have no bearing on the non-STP participating FI uplinks in port-fast mode.
Kirk...
Thanks for the reply.  I appreciate the feedback.
We originally had these setup in a stack but had issues.  These switches don't support a rolling upgrade and we did not realize this.  The first firmware upgrade we did caused havoc.   Since both switches booted at the same time all the servers shutdown since they didn't detect a network connection.  It took us two days to recover.
