after uninstall and reinstall the management pack to link another user the MP doesn't work
aborgeld1
Version Cisco UCS MP: 2.6.2
After uninstall and reinstall the management pack to link another user, the MP doesn't work.
I installed the MP in elevation and choose to install all.
Then when i start the Authoring console and choose -> Management pack templates -> Cisco Unified Computing Systems -> Add monitoring wizard -> click once again on Cisco UCS, then i get the following error:
Error in Opsmgr 2012 r2
Note:  The following information was gathered when the operation was attempted.  The information may appear cryptic but provides context for the error.  The application will continue to run.
Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.UISDKException: The page could not be loaded. Please review the errors and try again. ---> Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.UISDKException: The page could not be loaded. Please review the errors and try again. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at Cisco.UCS.MP.UI.Proxy.Template.Page.ProxyDetailsPage.LoadPageConfig()
   at Microsoft.EnterpriseManagement.Mom.Internal.UI.Console.ConsoleJobExceptionHandler.ExecuteJob(IComponent component, EventHandler`1 job, Object sender, ConsoleJobEventArgs args)
   --- End of inner exception stack trace ---
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.PageWrapper.LoadPageConfig()
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.PageWrapper.OnPageAdded()
   at Microsoft.EnterpriseManagement.ConsoleFramework.WizardFramework.AddPage(Page page)
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Extensibility.PageManagerBase.AttachToFramework(IPageFramework pageFramework, Boolean readOnly)
   at Microsoft.EnterpriseManagement.Internal.UI.Authoring.Pages.TemplateListPage.AddPagesForSelectedItem()
Geevarghese Cheria
Hi Andre,
Please refer Cisco UCS Manager Management Pack for Microsoft SCOM (version 2.6.1)
for related information regarding
Thanks and Regards,
Geevarghese
I've solved this with the new UR 2 SCOM binary
