Bandwidth Maximums on UCS virtual NICs
notofthisearth
I'm creating some virtual NICs for ESXi hosts.
What is the maximum bandwidth per virtual NIC?
If I have 4 virtual NICs on a virtual switch in ESXi, what is the maximum bandwidth for the total of the 4 virtual NICs?
Manuel Velasco
Hi The total bandwidth doesn't depend on the number of vnics it depends on the blade model, adapter(s), and the type of IOM that you have installed (see link below) . http://ucsguru.com/2013/03/13/20gb-20gb-10gb-m3-blade-io-explained/
It also depends on the number of links between the IOMs and the fabrics interconnects
