Cisco UCS Platform Emulator, Release 4.1(2cPE1)
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
New Features and Significant Changes in Cisco UCS PE, Release 4.0(4ePE1)
Hardware Feature Summary
Please see the Release Notes for a complete list of supported Hardware. Below is a summary:
Known Limitations
IMPORTANT CONFIGURATION NOTE: Backup/Import of UCSM Configuration
Firmware Management: UCSPE supports uploading B-Series and C-Series server firmware bundles. Because of the large file sizes of the firmware bundles, UCSPE only supports uploading of stripped-down versions (link below). Stripped-down versions include only the firmware metadata (not the actual firmware binaries).
Download Instructions
MD5 hashes for downloads:
This version of the Platform Emulator, as well as version 4.0.4(e) does not allow the successful changing of Fabric Interconnect model. Selecting the options from the GUI simply leads to a broken web page. Please fix as it is quite useful to change the virtual Fabric Interconnect model to better replication a production environment.
Seems to me the changing FI feature does not work. I'm did a full clean of the devices, change FI a Mini and it won't change it. Not even a full restart. Please fix this.
Changing the FI works fine for me:
* clean install of UCSPE
* wait to be safe one minute longer than it seems to be needed
* change the FI-Type (i'm using "UCS 6332 16UP" right now)
* wait 15 Minutes
that's it.
Has the download linked been broken?
I can not access the link.
I cant dowload to
Is there a Cisco UCS Platform Emulator 4.1(2cPE1) User Guide?
I was pretty competent in an older version of UCSPE to add and delete devices. But I was _really_ struggling with the device inventory in 4.1.2c until I found this YouTube video: https://www.youtube.com/watch?v=KQ8sHagBrzY
Hope this saves you some time.
Greetings! Is this software still available? The download link does not appear to work any more, and there doesn't appear to be any other way of downloading this software other than through these forums.
This link works: https://software.cisco.com/download/beta/1850014776
The download links go to an empty cisco download page. Does one need permisisons to download the ova?
For anyone struggling with the download link - I found opening it up in a different browser session allows me to login with my cisco.com account and access the software - could just be how the auth is handled from the community page to the software downloads page.
How I can add Expander Card (UCS-MLOM-PT-01) to B200-M3 with 1240 VIC (UCSB-MLOM-40G-01) in UCS Platform Emulator?
Thank you in advance
I cant download the file, error meeage is:
The proxy server received an invalid response from an upstream server.
Additionally, a 400 Bad Request error was encountered while trying to use an ErrorDocument to handle the request.
I can access the download here: https://software.cisco.com/download/beta/1850014776
I think you have to be authenticated with CCO credentials.
