Lan or San pin group in UCSM
Hele Du
Hi everybody,
    I am confuse with the vNic and vHBA template setting in  UCSM. Could anyone help me ?
    From vNic template, we can define the Fabric ID and pin group.
    If I define a pin group which is go to Fabric B, and choose the fabric A in vnic template setting.
    How does the traffic goes on?
    which FI does the vnic will create on?
    As far as i know, pin group is a static pinning , and fabric id is a dynamic pinning.
    I attached a screenshot.
    In "fabric ID" , I chosen fabric A and tick "enable failover"
    In "pin group", i selected specific "PIN to FIB"
Static pinning will overwrite dynamic pinning; however, if you have a mixture of static/dynamic pinning with different Interfaces of a Service Profile, then a particular uplink is not used exclusively for static pinning, it is shared with both pinnings; this essentially means, either everything should be static pinning nor nothing (=dynamic). Another argument for not using static pinning.
I hope this is clear ?
6 Replies 6
Walter Dey
Just a General comment:
- I would never recommend to do static pinnning. Why ? it is great to control where your traffic goes, however, if your Installation becomes bigger (whatever that means), it's a Management nightmare; I know not a single customer that is using it therefore.
- for Ethernet, there is a reshuffling mechanism in place, that distributes outgoing traffic equally over all outgoing links; not available for FC.
- the use of the Failover flag has been discussed in this Forum extensively. The recommendation: if your OS supports loadbalancing and Failover, then let the OS do it, and don't enable Hardware Failover; eg. ESXi, W2012,....
- Never ever use OS Failover AND Hardware Failover enabled; this can lead to ugly behaviour.
Cheers
Walter.
Thanks Wdey.
       Goog to see you again.
       Thank you for your  comment.From your comment the static pinning was a bad choose.
       If choose the dynamic pinning and select a pin group at same time in vNIC template ,what will happen?
Thanks Wdey,
         I`m already clear about this issue , thanks again.
Hi Wdey,
  As far as I know, FI uses adapter FEX to acommpuish VIF, when I choose "Fabric ID-A" in vnic setting , it will cerate a VIF on FIA.
   Return back to this question, If I chosen the "Fabirc ID A" and select a specific Pinning group to FIB, the VIF will cerate on which FI?
This would be a weird (wrong) configuration; a vnic attached to Fabric A, would use a pin Group using a North bound link on FI-A.
