Monitoring Cisco UCS Manager via HP System Information Manager 7.1 (SIM)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-14-2013 07:48 AM - edited 03-01-2019 10:55 AM
I am working with a customer to configure HP System Information Manager 7.1 (SIM) to monitor their Cisco UCS Manager.
The customer is looking to monitor the following:
- CPU Utilization on manager, blades, servers, etc...
- Memory utilization
- Network utilization
- System inventory
Alerting is needed for the following:
- Hardware failures: memory, power supply, drive, etc...
- Predictive failures
- Alert messages
I have the list of all the MIBs provided by Cisco but an having the following issues while loading them into HP SIM.
While loading MIB "CISCO-UNIFIED-COMPUTING-TC-MIB" I get the following error message:
- Line 128: Error defining object: expected a label, found reserved symbol {
- Line in MIB: SYNTAX Gauge32 {
- Guage32 is imported from SNMPv2-SMI MIB
To get past this error I found a version of the MIB that removes all the textual conventions that where causing errors. I have attached the fixed MIB file to this discussion. With the fixed version of the MIB installed in SIM everything compiles and installs except the following two MIBS. CISCO-UNIFIED-COMPUTING-NOTIFS-MIBCISCO-UNIFIED-COMPUTING-CONFORM-MIB Questions:
- 1. Is there any way to get the CISCO-UNIFIED-COMPUTING-TC-MIB MIB to install correctly into HP SIM?
- 2. Is my MIB load order setup correctly?
- 3. Has anyone had success getting HP SIM to monitor and alert for Cisco UCS manager?
MIB Load Order:
SNMPv2-SMI
SNMPv2-TC
SNMP-FRAMEWORK-MIB
RFC1213-MIB
IF-MIB
CISCO-SMI
CISCO-ST-TC
ENTITY-MIB
INET-ADDRESS-MIB
CISCO-UNIFIED-COMPUTING-MIB
CISCO-UNIFIED-COMPUTING-FAULT-MIB
CISCO-UNIFIED-COMPUTING-AAA-MIB
CISCO-UNIFIED-COMPUTING-ADAPTOR-MIB
CISCO-UNIFIED-COMPUTING-BIOS-MIB
CISCO-UNIFIED-COMPUTING-BMC-MIB
CISCO-UNIFIED-COMPUTING-CALLHOME-MIB
CISCO-UNIFIED-COMPUTING-CAPABILITY-MIB
CISCO-UNIFIED-COMPUTING-COMM-MIB
CISCO-UNIFIED-COMPUTING-COMPUTE-MIB
CISCO-UNIFIED-COMPUTING-DCX-MIB
CISCO-UNIFIED-COMPUTING-DHCP-MIB
CISCO-UNIFIED-COMPUTING-DIAG-MIB
CISCO-UNIFIED-COMPUTING-DPSEC-MIB
CISCO-UNIFIED-COMPUTING-EPQOS-MIB
CISCO-UNIFIED-COMPUTING-EQUIPMENT-MIB
CISCO-UNIFIED-COMPUTING-ETHER-MIB
CISCO-UNIFIED-COMPUTING-EVENT-MIB
CISCO-UNIFIED-COMPUTING-EXTMGMT-MIB
CISCO-UNIFIED-COMPUTING-EXTVMM-MIB
CISCO-UNIFIED-COMPUTING-FABRIC-MIB
CISCO-UNIFIED-COMPUTING-FC-MIB
CISCO-UNIFIED-COMPUTING-FCPOOL-MIB
CISCO-UNIFIED-COMPUTING-FIRMWARE-MIB
CISCO-UNIFIED-COMPUTING-FLOWCTRL-MIB
CISCO-UNIFIED-COMPUTING-HOSTIMG-MIB
CISCO-UNIFIED-COMPUTING-IMGPROV-MIB
CISCO-UNIFIED-COMPUTING-IMGSEC-MIB
CISCO-UNIFIED-COMPUTING-IPPOOL-MIB
CISCO-UNIFIED-COMPUTING-IQNPOOL-MIB
CISCO-UNIFIED-COMPUTING-ISCSI-MIB
CISCO-UNIFIED-COMPUTING-LICENSE-MIB
CISCO-UNIFIED-COMPUTING-LLDP-MIB
CISCO-UNIFIED-COMPUTING-LSBOOT-MIB
CISCO-UNIFIED-COMPUTING-LSMAINT-MIB
CISCO-UNIFIED-COMPUTING-LS-MIB
CISCO-UNIFIED-COMPUTING-MACPOOL-MIB
CISCO-UNIFIED-COMPUTING-MAPPINGS-MIB
CISCO-UNIFIED-COMPUTING-MEMORY-MIB
CISCO-UNIFIED-COMPUTING-MGMT-MIB
CISCO-UNIFIED-COMPUTING-NETWORK-MIB
CISCO-UNIFIED-COMPUTING-NWCTRL-MIB
CISCO-UNIFIED-COMPUTING-ORG-MIB
CISCO-UNIFIED-COMPUTING-OS-MIB
CISCO-UNIFIED-COMPUTING-PCI-MIB
CISCO-UNIFIED-COMPUTING-PKI-MIB
CISCO-UNIFIED-COMPUTING-PORT-MIB
CISCO-UNIFIED-COMPUTING-POWER-MIB
CISCO-UNIFIED-COMPUTING-PROCESSOR-MIB
CISCO-UNIFIED-COMPUTING-PROC-MIB
CISCO-UNIFIED-COMPUTING-QOSCLASS-MIB
CISCO-UNIFIED-COMPUTING-SOL-MIB
CISCO-UNIFIED-COMPUTING-STATS-MIB
CISCO-UNIFIED-COMPUTING-STORAGE-MIB
CISCO-UNIFIED-COMPUTING-SW-MIB
CISCO-UNIFIED-COMPUTING-SYSDEBUG-MIB
CISCO-UNIFIED-COMPUTING-SYSFILE-MIB
CISCO-UNIFIED-COMPUTING-TOP-MIB
CISCO-UNIFIED-COMPUTING-TRIG-MIB
CISCO-UNIFIED-COMPUTING-UUIDPOOL-MIB
CISCO-UNIFIED-COMPUTING-VM-MIB
CISCO-UNIFIED-COMPUTING-VNIC-MIB
References:
ftp://ftp.cisco.com/pub/mibs/supportlists/ucs/ucs-manager-supportlist.html#_Toc303691433
http://www.hp.com/wwsolutions/misc/hpsim-helpfiles/simsnmp.pdf
- Labels:
Unified Computing System (UCS)
