timoma
Overview:
A virtualized server implementation consists of one or more VMs running as 'guests' on a single physical server. The guest VMs are hosted and managed by a software layer called the hypervisor or virtual machine manager (VMM). The hypervisor typically presents a virtual network interface to each VM and performs Layer 2 switching of traffic from a VM to other local VMs or to a physical interface to the external network. Working with a Cisco virtual interface card (VIC) adapter, Cisco Virtual Machine Fabric Extender (VM-FEX)bypasses software-based switching of VM traffic by the hypervisor in favor of external hardware-based switching in the fabric interconnect. This method results in a reduced load on the server CPU, faster switching,and the ability to apply a rich set of network management features to local and remote traffic. VM-FEX extends the (prestandard) IEEE 802.1Qbh port extender architecture to the VMs, providing each VM interface with a virtual Peripheral Component Interconnect Express (PCIe) device and a virtual port ona switch. This solution allows precise rate limiting and quality of service (QoS) guarantees on the VM interface.
Infrastructure Requirements
  • Nexus VMware VM-FEX is available with Nexus 5500 Series and UCS standalone C series with VIC (P81E,VIC1225, VIC1225T)
  • Each VIC card supports up to 96 Virtual Machine Interface
  • Enterprise Plus License required (as is for any DVS) on Host
  • Standard License and above is required for vCenter
  • Hypervisor features are supported for both emulated and hypervisor bypass mode
     – vMotion, HA, DRS, Snapshot and Hot add/remove virtual device, Suspend/Resume
  • VMDirectPath (Hypervisor Bypass) with VM-FEX is supportted with ESXi5.0+
  • VM-FEX upgrade is supportted from ESXi4.X to ESXi5.X with Customized ISO and VMware Update Manager
VM-FEX Mode of Operations
VMware
VMware
VM-FEX Mode
Emulation
Hypervisor Bypass
Hypervisor Version
ESX 4.0 U1 +
ESXi 5.0 +
Minmum NX-OS Version
5.1(3)N1(1)5.1(3)N1(1)
Minimum VIC Firmware Version
P81E:         1.6(2a)
VIC1225:     HUU 1.5.1(b)
VIC1225T:   HUU 1.5.1(b)
P81E:             1.6(2a)
Minimum CIMC Version
P81E:         1.4(2.3)
P81E:             1.4(2.3)
VMotion / Live Migration
SupportSupport
Support Guest OS Any OS support by ESX/ ESXi
RHEL 6.0+ , SLES 11+
Window 2008 SP2, Windows 2008 R2, Windows 2012
Guest OS/vSphere Version
vSphere 5.0
vSphere 5.0 U1
vSphere 5.1
Windows 2012N/A1.2.24.0 (vmwaretools)1.3.9.0 (vmwaretools)
Windows 2008 R21.2.22.0 (vmwaretools)1.2.24.0 (vmwaretools)1.3.9.0 (vmwaretools)
Windows 2008 SP21.2.22.0 (vmwaretools)1.2.24.0 (vmwaretools)1.3.9.0 (vmwaretools)
RHEL 6.01.0.14.0-k (inbox)1.0.14.0-k (inbox)1.0.14.0-k (inbox)
RHEL 6.11.0.14.0-k (inbox)1.0.14.0-k (inbox)1.0.14.0-k (inbox)
RHEL 6.2N/A
1.1.18.0-k (inbox)
1.0.47.0 (vmwaretools)
1.1.18.0-k (inbox)
1.1.32.0 (vmwaretools)
SLES111.0.36.0 (vmwaretools)1.0.47.0 (vmwaretools)1.1.32.0 (vmwaretools)
SLES11 SP11.0.36.0 (vmwaretools)1.0.47.0 (vmwaretools)1.1.32.0 (vmwaretools)
VM-FEX Scalability
UCSM Configuration Limit 2.1 Release -http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/configuration_limits/2.1/b_UCS_Configuration_Limits_2_1.html
Cisco UCS 6100 / 6200 Series
Hypervisor
Half-Width Blade with Single VIC
Full-Width Blade with Dual VIC
ESX 4.0 – 4.1 (DirectPath I/O)
56 (54 vNIC + 2 vHBA)
ESXi 5.0 – 5.1 (DirectPath I/O)
116 (114 vNIC + 2 vHBA)
116 (114 vNIC + 2 vHBA)*
Windows 2012 (SR-IOV)
232 (228 vNIC + 4 vHBA)
KVM 6.1 – 6.3 (SR-IOV)
* Additional VIC will NOT increase the total VIF count due to OS limitation
* Multiple VICs are Supported for full width blade and B200M3
Nexus 5500  Series
HypervisorAdapter FEXVM-FEX
ESX 4.1 – ESXi 5.1
96 vNIC
96 vNIC
* Only one VIC (P81E/VIC1225) is Supported for each C series rack server
Nexus Verified Scalability 6.0(2)N1(1) release
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5500/sw/configuration_limits/b_N5500_Config_Limits_602N11_chapter_01.html#reference_BCDAA1182FD641C3B350AC9C1825050A
Feature
Verified Topology
Verified Maximum
Number of VFCs over Virtual Ethernet Interfaces40 40
Number of Port Profiles1,0001,000
Number of Virtual Machines (VMs) Concurrently not VMotioned5 VMs with 10 vNICs each5 VMs with 10 vNICs each
Number of Virtual Ethernet Interfaces Enabled with vNIC Shaping2,0002,000
Number of Virtual Ethernet Interfaces Enabled with Untagged CoS2,0002,000
Server - Number of Adapters per Server11
Server - Number of vNICs per Server5096
VM-FEX Feature Comparision
Feature
N5K
Adapter FEX
N5K
VM-FEX
UCS
VM-FEX
ERSPANYes
SPAN YesYes
FCoEYesYesYes
Port Security YesYesYes
IGMP Snooping YesYes
Qos Shaping YesYesYes
QoS Classification Yes YesYes
PVLANYes YesIsloate
L2 Multipath Edge Port Edge Port
TrustSec Yes Yes
IPv4/IPv6/MAC ACLYesYes
DHCP Snooping YesYes
IP Source Guard YesYes
SNMP YesYes
Netflow+
Yes
Reference Documentation
Nexus VM-FEX Configuration Guide
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/mkt_ops_guides/513_n1_1/n5k_ops_vmfex.html#wp1075280
Cisco-Live-BRKCOM-2005-Virtual Machine Fabric Extension (VM-FEX)-2013
VM-FEX Configuration & Best Practice for Multiple Hypervisor
Please refer to the attachmenta
Cisco VM-FEX Performance Testing verus VMware vSwitch
http://www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns224/ns944/whitepaper_c11-727581.html
External (Light Reading) VM-FEX Peroformance Testing verus VMware vSwitch
http://www.lightreading.com/document.asp?doc_id=693092
VM-FEX Performance Testing with SAP
http://www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns224/ns944/whitepaper_c11_703103.pdf
VM-FEX Performance Testing with Microsoft SharePoint 2010
http://www.cisco.com/en/US/docs/unified_computing/ucs/UCS_CVDs/ucs_sharepoint2010_flexpod_vmware.html#wp402742
VM-FEX Performance Testing with Microsoft SQL Server 2012
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10281/whitepaper_c11-711915.html
VM-FEX Performance Testing with Citrix Xenapp 6.5
http://www.cisco.com/en/US/docs/unified_computing/ucs/UCS_CVDs/citrix_emc_ucs_XDXAscale.pdf
Microsoft Private Cloud Fast Track 3.0 with VM-FEX
Video Configuration Demo Topology
  • Nexus 5548/C22 M3/ VIC1225/ESXi
  • Nexus 5548-A is pre-configured, focus on 5548-B with the same configuration in the demo
  • Uplink Redundancy – Each static vNIC configure as Active/Standby
     -No need for OS teaming software
     -Required for hypervisor uplink
  • Each dynamic vNIC attach to uplink in Round Robin fashion
  • vPC Doman and Peer Link is configured to synchronize veth numbering for the same VM
          -Not used for the forwarding plane
Nexus 5500 VM-FEX Configuration Workflow
Video Link : 11359
mihaitanasescu
Dumb question from my part and maybe someone can clear it up:)
As each vNIC has a failover (uplink failover) shouldn't we define vethernet 1, respectively vethernet 2 on both Nexus?
Ex:
on both
interface vethernet 2
bind interface eth102/1/32 channel 2
and
interface vethernet 1
bind interface ethernet 102/1/32 channel 1
Hope someone can help clear this up,
Mihai
