I am using the UCS Emulator v1.3 and I cannot find a way to connect to the ESX host that comes pre-installed with it. Also the v1.4 Emulator is stuck on "Starting Cisco UCSPE & UCS Manager: 203%" and increasing...
Any help would be appreciated
Derek
hello:
I have the ucs v2 book.
I did install the simulator. I already have a copy of vm workstation 5 running
I can
-start vm workstation 5
-open the ucs sim vm file both V1.1 and V2.0
-power on the ucs sim
-open the web page for the ucs gui
When I try to log in (not kvm) it tries, but I get a consistent java issue
both version start the jave app, but they are both hung in "downloading applicaation" see the attached screen shot of both version running
I have latest jdk version 6 rel 29
My cisco ccp needs jdk also and it works fine. Google search found others with issues but no useful soln
Any ideas? The machine is running win 7 with 4 gb ram. I have both ff and ie browsers
any ideas?
I have tried both V1.1 and V2.0
both
