UCS Management Pack 4.1 SCOM - Connection to IMC server failed
MrDibbley
Running SCOM 2012 R2 with the 4.1 UCS management pack, discovered and monitoring the central UCS fine, we have 28 remote IMC's we are trying to monitor, when added in pairs either one of both fail with login error and SCOM stops monitoring them, i have turned up logging to debug and the only error displayed is:
DEBUG : 13 : 2018-02-28 09:33:50 : Entry: UcsImcAgent.PopulateClassDataCache(imcServer = Cisco.UcsService.UcsImc.IMCServerDetails, cacheClasses = System.Collections.Generic.List`1[System.String])
ERROR : 10 : 2018-02-28 09:33:52 : Error in the application.
ERROR : 10 : 2018-02-28 09:33:52 : at Cisco.Imc.ImcHandle.Login(String name, String userName, SecureString password, Boolean noSsl, Nullable`1 port, Action`1 dumpXml)
at Cisco.UcsService.UcsImc.UcsImcConnector.Connect()
at Cisco.UcsService.UcsImc.UcsImcAgent.PopulateClassDataCache(IMCServerDetails imcServer, List`1 cacheClasses)
INFO : 10 : 2018-02-28 09:33:52 : UcsImcAgent.PopulateClassDataCache() - connection to IMC server (10.40.21.69) failed.
INFO : 10 : 2018-02-28 09:33:52 : UcsImcAgent.PopulateClassDataCache() - disconnecting from : 10.40.21.69
INFO : 13 : 2018-02-28 09:33:56 : UcsImcAgent.PopulateClassDataCache() - connection to IMC server (10.40.21.68) established.
INFO : 13 : 2018-02-28 09:33:56 : UcsImcAgent.PopulateClassDataCache() - successfully verified version of IMC server : 10.40.21.68
INFO : 13 : 2018-02-28 09:33:59 : UcsImcAgent.PopulateClassDataCache() - disconnecting from : 10.40.21.68
i have tried different servers with the monitoring service same result, also changed from https to http again same problem.
any suggestions as to what we can tweak?
SJMarty
I am having the same exact issue.  UCC and UCS domains discover correctly but adding an IMC server always returns the following error message...
Login failed for IMC IP addresses:
XXX.XXX.XXX.XXX
Were you ever able to get this resolved?
Thanks.
Please go ahead a raise a case with Cisco support team here: Cisco Support - Software Downloads, Product Documentation, Support Tools, and Support Cases - Cisco Systems
-Amit Kumar
