UCS Vlan 1 issue
amoussaPersonal
I have an issue with Vlan 1 on the UCS (Version 2). the setup is as follows
Fabric Interconnect (port channel - trunk) --> Nexus 5K (Port Channel trunk) --> 6500
Esx 4.1 is installed on each Blade server.
All vlans are working normally except Vlan 1 (Vlan 1 is used in our enviroment)
all truncks between N5K and 6500 have vlan 1 as native.
how should I configure the Vmware Distributed Switch and UCS Server Profile ( vNic Native Vlan) and FI (Native Vlan)?
amoussaPersonal
Just for update, I have created a dvPort on the VMware distributed switch with No Vlan Tagging.
In addition you need to set the default VLan on the Fabric interconnect to Vlan 1.
Set the native Vlan on the UCS profile vNic to a different Vlan ID (Other than 1)
