Understanding output of : ucsm-B(nxos)# sh int br
Hi All ,
Could you please help me understand the output of the following command :
I have a few queries on the interfaces number eth1/1/1 to eth 1/1/8 :
What governs the naming convetion used for the ethernet ports starting eth1/1/1 to eth1/1/9 ?
If I connect another chassis to the FI , will it start by eth2/1/1 ?
I would like to understand how Eth1/x/x or Eth2/x/x is decided by the UCS for naming ..
--------------- truncated -----------------------------------------------------------------------------------------------------
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
vfc684     102    F      on      trunking         --     TF      auto --
vfc688     102    F      on      trunking         --     TF      auto --
Ethernet      VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1/1      1      eth  vntag  up      none                        10G(D) --
Eth1/1/2      1      eth  vntag  up      none                        10G(D) --
Eth1/1/3      1      eth  vntag  up      none                        10G(D) --
Eth1/1/4      1      eth  access down    Administratively down       10G(D) --
Eth1/1/5      1      eth  access down    Administratively down       10G(D) --
Eth1/1/6      1      eth  access down    Administratively down       10G(D) --
Eth1/1/7      1      eth  access down    Administratively down       10G(D) --
Eth1/1/8      1      eth  access down    Administratively down       10G(D) --
Eth1/1/9      4044   eth  trunk  up      none                        10G(D) --
padramas
Hello Vikas,
These are host interfaces ( HIF ) / backplane ports on the FEX / IOM connecting to the blades.
Eth//
" show fex detail " would provide additional information about FEX ports.
The ninth interface provides CIMC connectivity to the blades,
Padma
padramas
Hello Vikas,
Eth//
Padma
Thanks Padma for the quick reply ..
