Validate Flex flash Hypervisor Partition sync
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-26-2014 07:18 PM - edited 03-01-2019 11:28 AM
i have a number of ucs c220 m3's deployed with 2 flexflash cards in them. until recently we weren't aware of the need to conduct the hypervisor sync thru the SCU (http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/ucsscu/user/guide/314/gui.html#wp1095806) to bring the hypervisor partitions into a RAID-1 type configuration. is there a way to validate which servers have had their flexflash hypervisor partitions sycned or not?
- Labels:
Unified Computing System (UCS)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-26-2014 09:50 PM
When the hypervisor partition is not sync between the two SD cards, you will see an error message on the CIMC under the Storage tab after you select Cisco Flexflash controller. Note that this feature became available after firmware version 1.5, so if your servers are running code prior to that the raid configuration between the SD cards won't be available.
Please let me know if this help and rate any helpful post.
