Unified Computing System Discussions
Engage with peers and experts on UCS and HyperFlex topics.
Hello, Cisco Community.I studied working with UCS 6300 in gui. Initially, I had an ethernet port configured in vntag mode. A c240 server was connected to this port.As part of an experiment, I reconfigured the port in Apliance. I lost connection with ...
yak-dva86 by Level 1
  • 57 Views
  • 1 replies
Hello,I’m preparing to deploy a Windows Server 2025 Hyper-V cluster on a Cisco UCS X9508 chassis, and I’d like to understand the best practices for this setup.In particular, I’d appreciate advice on the following points:Recommended firmware versions ...
Resolved! Firmware Upgrade
Cisco UCSM running B200 M5'sToday I was performing infrastructure and server firmware upgrades.  My upgrade was going from 4.3(2f) to 4.3(3c).  The infrastructure upgrade was successful.  After creating my new host firmware package and modifying my u...
TroyS by Level 1
  • 215 Views
  • 1 replies
Hello FreindsI'm not able to launch the Cisco vKVM Console on UCS C240 M4 S2 to map the ISO , i m using the below JAVA Runtime versionPlease Advise jre-6u14-windows-i586errors below java logs<?xml version="1.0" encoding="UTF-8"?><jnlp codebase="https...
Hello FreindsI got (4x64GB) RAM for Cisco UCS C240 M4,  DDR4 2400MHz PC4-19200 ECC LRDIMM Now the server has only CPU-1 12 Cores , where to install this RAMs?is it on A1,B1,C1,D1 DIMMs Slots in order to be recognized by Serverpls advisethanks a lot
