How to dial Polycom RMX systems (IP##room number) through ExpressWay
reigo.rannak
Hi all
We have several SX10 endpoints registered to CUCM. External calling is through Expressway (C and E).
I'm able to make SIP calls like room@domain and also H323 calls with IP. But I have been looking for solution to call Polycom RMX 2000 system.
I have tried several options.
* Calling out with number@ip and make a transform in VCS-E and search rule will route this Traversal Zone.
* Calling out with ip*number@external and make also transform and search rule in VCS-E
There is no way to route "ip##room_number" out.
When I locate the number i get different errors like:
    • Found: False
    • Reason: Resource unavailable - Loop detected
    • Reason: Resolution failed
Does anyone have experience with that and can help me out?
reigo.rannak
Figured out that Polycom RMX will route call correctly when calling roomNumber**@IP
The ip##room format is a non-standard Polycom specific format and not supported by many other vendors.
You will need to change the format of what is dialled to room@ip.
This has been discussed on many occasions before in these forums.  Here's one thread where I provided a similar answer: https://supportforums.cisco.com/t5/telepresence/how-to-call-dx80-ce9-to-a-room-in-polycom-rmx/td-p/3394097
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
reigo.rannak
