02-10-2018 05:54 PM - edited 03-20-2019 10:22 PM
VOICE SYSTEM: Cisco Systems Small Business Pro UC560-FXO-K9 V01
PHONES: Cisco CP-7975G IP Phone Gig Ethernet, Color and 8 Lines
SWITCH: CISCO SWITCH POE 24 Ports
FIREWALL: Juniper SRX650-BASE-SRE6-645AP
SIP PROVIDER: VOIP Innovations
Coming from the world of Software PBX, like FreePBX, I am relatively new to Cisco UC systems. Now most of them are EOL, dropped in price and it's a perfect time to implement it for a small business.
QUESTIONS:
1. Out of the box, it is VOICE VLAN 100 and 10.1.1.x which I would like to change. How do I do that CCA or Console? What commands needed?
2. I was recommended VOIP Innovations as a VOIP provider for incoming and outgoing calls. Any other price/quality competitive suggestions?
3. What is needed and how to set up basic SIP trunking with this VOIP provider? (after provider gives necessary info)
4. Any other advice is greatly appreciated.
Thank you.
PS. The UC560 was reset to factory default with current config:
System Bootstrap, Version 15.0(1r)XA3, RELEASE SOFTWARE (fc1)
Copyright (c) 2010 by cisco Systems, Inc.
UC500 series platform with 524288 Kbytes of main memory
Readonly ROMMON initialized
program load complete, entry point: 0x80015000, size: 0x17e64
program load complete, entry point: 0x80020000, size: 0x28124b4
Self decompressing the image : ########################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X00137430 Onboard PVDM2 SIMM
0X00165000 Onboard Ethernet
0X00253000 Onboard VPN
0X000F3BB0 public buffer pools
0X00703000 public particle pools
TOTAL: 0X00CE5FE0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
adjusted iomem size up to minimum size of: 0X01A00000
Using 5 percent iomem. [26Mb/512Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Feb-13 10:17 by prod_rel_team
Cisco UC560-FXO-K9 (MPC8378) processor (revision 0x100) with 497664K/26624K bytes of memory.Installed image archive
Processor board ID FGL16121010
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
30 User Licenses
4 Gigabit Ethernet interfaces
2 terminal lines
1 Channelized (E1 or T1)/PRI port
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
!!By default, the following "voice service voip" !!
!!sub-command is enabled: !!
!! ip address trusted authenticate !!
!!The command enables the ip address authentication !!
!!on incoming H.323 or SIP trunk calls for toll fraud !!
!!prevention supports. !!
!!Please use "show ip address trusted list" command !!
!!to display a list of valid ip addresses for incoming !!
!!H.323 or SIP trunk calls. !!
!!Additional valid ip addresses can be added via the !!
!!following command line: !!
!! voice service voip !!
!! ip address trusted list !!
!! ipv4 <ipv4-address> [<ipv4 network-mask>] !!
Press RETURN to get started!
*Jan 27 00:21:44.619: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Jan 27 00:21:44.683: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Jan 27 00:22:16.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jan 27 00:22:16.447: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Jan 27 00:22:16.447: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Jan 27 00:22:16.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface Integrated-Service-Engine0/0, changed state to up
*Jan 27 00:22:16.923: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Jan 27 00:22:17.067: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 27 00:22:17.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Jan 27 00:22:17.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Jan 27 00:22:19.015: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
*Jan 27 00:22:19.215: %LINK-5-CHANGED: Interface Integrated-Service-Engine0/0, changed state to administratively down
*Jan 27 00:22:19.215: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/3, changed state to up
*Jan 27 00:22:19.215: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/2, changed state to up
*Jan 27 00:22:19.215: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/1, changed state to up
*Jan 27 00:22:19.215: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/0, changed state to up
*Jan 27 00:22:20.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface Integrated-Service-Engine0/0, changed state to down
*Jan 27 00:22:20.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/3, changed state to up
*Jan 27 00:22:20.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/2, changed state to down
*Jan 27 00:22:20.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/1, changed state to down
*Jan 27 00:22:20.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/0, changed state to down
*Jan 27 00:22:20.383: %SYS-5-RESTART: System restarted --
*Jan 27 00:22:20.383: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Jan 27 00:22:20.399: %SYS-6-BOOTTIME: Time taken to reboot after reload = 74 seconds
*Jan 27 00:22:20.407: %SMHM-5-START: Service module environmental health-monitor started
*Jan 27 00:22:20.431: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jan 27 00:22:21.623: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
*Jan 27 00:22:22.955: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
*Jan 27 00:22:24.295: %DSPRM-5-UPDOWN: DSP 3 in slot 0, changed state to up
*Jan 27 00:22:25.659: %DSPRM-5-UPDOWN: DSP 4 in slot 0, changed state to up
*Jan 27 00:22:28.531: %DSPRM-5-UPDOWN: DSP 5 in slot 0, changed state to up
*Jan 27 00:22:29.863: %DSPRM-5-UPDOWN: DSP 6 in slot 0, changed state to up
*Jan 27 00:22:31.195: %DSPRM-5-UPDOWN: DSP 7 in slot 0, changed state to up
*Jan 27 00:22:32.527: %DSPRM-5-UPDOWN: DSP 8 in slot 0, changed state to up
*Jan 27 00:22:41.003: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/0, changed state to up
*Jan 27 00:22:41.403: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/1, changed state to up
*Jan 27 00:22:41.403: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/2, changed state to up
*Jan 27 00:22:41.403: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/3, changed state to up
*Jan 27 00:22:41.403: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, changed state to up
*Jan 27 00:22:41.403: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/1, changed state to up
*Jan 27 00:22:41.403: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/2, changed state to up
*Jan 27 00:22:42.951: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/3, changed state to up
*Jan 27 00:22:42.951: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/0, changed state to up
*Jan 27 00:22:42.951: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/1, changed state to up
*Jan 27 00:22:42.951: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/2, changed state to up
*Jan 27 00:22:42.951: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/3, changed state to up
*Jan 27 00:22:48.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Router>
*Jan 27 00:26:51.675: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/2, changed state to up
*Jan 27 00:26:52.675: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/2, changed state to up
*Jan 27 00:26:53.939: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/2, changed state to down
*Jan 27 00:27:06.599: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/1, changed state to up
*Jan 27 00:27:20.575: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/0, changed state to up
*Jan 27 00:27:21.575: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/0, changed state to up
*Jan 27 00:27:24.523: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1/0, changed state to down
Router>en
Router#show inv
NAME: "UC560-FXO-K9 Chassis", DESCR: "UC560-FXO-K9 Chassis"
PID: UC560-FXO-K9 , VID: V01, SN: FGLXXXXXXXX
NAME: "2nd generation four port FXO voice interface daughtercard in DaughterCard Slot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V04 , SN: FOCXXXXXXXX
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 in DaughterCard Slot 3", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN: FOCXXXXXXXX
Router#show license
Index 1 Feature: uc-user
Period left: Life time
License Type: Permanent
License State: Active, Not in Use
License Count: 16/0/0 (Active/In-use/Violation)
License Priority: Medium
Router#show hardware
ROM: System Bootstrap, Version 15.0(1r)XA3, RELEASE SOFTWARE (fc1)
Router uptime is 9 minutes
System returned to ROM by reload at 00:21:05 UTC Sat Jan 27 2018
System image file is "flash:uc500-advipservicesk9-mz.151-4.M6"
Last reload type: Normal Reload
Last reload reason: Reload Command
30 User Licenses
2 terminal lines
License Info:
License UDI:
Device# PID SN
*0 UC560-FXO-K9 FGLXXXXXXXXX
Router#show flash:
-#- --length-- -----date/time------ path
1 42018388 Oct 15 2013 03:22:34 +00:00 uc500-advipservicesk9-mz.151-4.M6
2 69 Jan 26 2018 23:55:24 +00:00 syncinfo.xml
3 1993 Jan 26 2018 23:55:24 +00:00 SIPDefault.cnf
4 4342 Jan 26 2018 23:55:24 +00:00 softkeyDefault_kpml.xml
5 4376 Jan 26 2018 23:55:24 +00:00 softkeyDefault.xml
6 825 Jan 26 2018 23:55:26 +00:00 featurePolicyDefault.xml
214458368 bytes available (42049536 bytes used)
Router#
02-16-2018 08:06 AM
The articles posted are lengthy.
Can you please specify which article and which PAGE(S) refer to the following:
1. Changing 10.1.1.x default Network
2. SIP Trunking setup
3. RTP settings
02-16-2018 08:30 AM
02-16-2018 09:18 AM
Thank you for your assistance.
There are 62 pages in second article PDF on IP addressing.
Which page are you referring to?
02-16-2018 09:41 AM
02-17-2018 10:23 AM
So I have a specific question now: can I change 10.1.1.x default subnet on UC560 and how?
Which page in the article talks about that?
02-20-2018 04:08 AM
02-20-2018 04:34 PM
So this looks like you changed interface IP but my question is regarding default VLAN 100 which by default uses 10.1.1.x subnet which will assign DHCP IPs to the phones. Right?
For example:
Phone 1 = 10.1.1.2
Phone 2 = 10.1.1.3 etc
How do I change the DHCP assignments to another subnet for example instead of 10.1.1.x i want to reaplce it with 10.1.100.x?
since I have cisco phones its SCCP between phones and UC560.
SIP between UC560 and VOIP provider.
02-20-2018 05:04 PM
02-20-2018 08:54 PM
Sure.
While I am getting show run info for you, can this change we speak of only be achieved through cli or I can do the same with CCA?
Is CCA limited to what it can do?
FYI: the UC560 was reset to factory defaults.
02-20-2018 09:56 PM
02-21-2018 03:44 PM - edited 02-21-2018 03:47 PM
Can CCA push config that we are discussing here i.e. different subnet, vlan etc?
Is CCA capable doing that or only predefined config?
If not, can I just use CLI to configure the box and completely ignore CCA?
Or I will still need CCA to configure phones etc?
After I configure the box using CLI but then use CCA, wouldn't CCA rewrite all the changes i made initially using CLI?
02-21-2018 04:09 PM
02-21-2018 04:41 PM
Are there screenshot or videos available on how to do what I need?
Also the very first screen it is asking to create site?
How do you actually connect?
02-23-2018 07:30 AM
02-25-2018 07:48 AM
For the PC that gets plugged into UC560 via RJ45 cable, should the PC be set to receive IP from UC560 automatically via DHCP or assign new IP address to be on the same subnet as UC560? I believe it's 192.168.x.x subnet?
