33.6 modem connecting though VG224 hangs up
Adam Van Slyke
I'm looking for some help in trying to understand and resolve this problem:
One of our contractors uses a US Robotics 33.6 modem from his home office to connect to a modem on our site. He get's the handshake signal, but when he is prompted to enter his credentials, he looses signal.
The generic pathway is
Home Office Modem [US Robotics 33.6] ---> VG224 [Ver. 12.4(24)T] and CUCM Ver 7.1.5 ---> end device modem
On our VG:
  voice service voip
    fax protocol pass-through g711ulaw
    modem passthrough  nse codec g711ulaw
I've read through other troubleshooting blogs on this that it could be because t.38 is disabled; I have since enabled the t.38 fax relay on the VG and within CUCM.
Has anyone else ran into the same issue?
Adam
5 Replies 5
Adam Van Slyke
Additionally,  on our CM Gateway I've enabled:
mgcp fax t38 ecm
just for clarification.
So there is another analog GW on the CUCM side correct?
both GWs have to understand the nse and they both have to go into modem relay mode:
http://www.cisco.com/en/US/docs/ios/voice/fax/configuration/guide/vf_cfg_mdm_psthr_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1035681
Is
voice service voip
configured on the other GW?  Sniff between the GWs and make sure the nse(you will see different payload type in the RTP stream) gets responded to - also do a sh call act voice - make sure both GWs go to g711 during the modem call.    If there is any h323 involved make sure you are not hitting the default dial-peer.
Pathway is
Telco-PRI-GW-MGCP-CUCM-SCCP-VG224-Modem
I have found this link
https://supportforums.cisco.com/docs/DOC-25210
Which is helpful but only shows Telco-PRI-GW-CUCM-MGCP-VG224_modem instead of SCCP between Call Manager and VG.
Chester,
We're using IOS 12.4(24)T3, and I have seen on Cisco that T2 had issues with the gateway not being able to seperate modem and fax calls. What I can't find is if this issue was for sure fixed in version T3...?  Any insight on that?
Tim
