Add TCL Subscribe/Notify for SIP Registration to ISDN-SIP GW
Alfred Johnson
We have a need to add SIP SUBSCRIBE/NOTIFY messaging for SIP Registration events not supported in our current ISDN PRI to SIP+VoIP gateway on IAD2431 and ISR2921 IOS voice gateways (VGW).  When a provisioning change is made to the VGW's IMS account, such as adding or deleting telephone numbers to the client PBX served by the VGW, the IMS automatically de-registers the VGW, which I believe is per 3GPP IMS spec.  At this point, the IMS will not route incoming calls to the PBX, because it does not have a valid SIP Registration.  This is a major service outage for the PBX customer that will last until the VGW's registration expires and it re-registers.
The 3GPP IMS spec says the VGW should send a SIP SUBSCRIBE message for registration events to the IMS immediately after it registers.  Then when a provisioning event causes the IMS to de-register the VGW, the IMS will send a SIP NOTIFY to the VGW informing it that it has been de-registered. When the VGW registers recieves the NOTIFY we need to get the VGW to immediately re-register, which will then allow the IMS to route inbound PBX calls over SIP to VGW, which sends the call to to the PBX over ISDN Q.931 on the PBX's T1.  Because the existing IOS SIP user agent does not support this capability natively, we want to add it using TCL or IOS EEM scripts.
We have already used EEM scripting to detect and respond to other SIP Registration fault scenarios that are problematic with the IOS SIP UA.  We use EEM to poll the state of the IOS SIP UA by querying its SNMP OIDs.  Then we use the EEM script to generate CLI commands to enter IOS configuration mode, delete the SIP UA's registrar command, and then add it back in.  This makes the VGW try to Register again promptly, where otherwise a significant outage period would occur.
The IOS SIP Config Guide has several sections covering SUBSCRIBE and NOTIFY capabilities, but we need to find documentation or someone with experience on how to configure the use TCL to trigger the SIP UA to generate a SUBSCRIBE message on command, and to trigger an EEM event when it receives a NOTIFY.  Does anyone have any experience with this type of application?  Can you point us to existing documentation, or contribute example configs, scripts and debug traces?
11 Replies 11
torsten.brink
Hi Alfyj,
did you ever found a solution for that issue? Or at least some kind of Workaround.... I've a pretty similar issue.
Torsten
I have not found a good solution to this problem.  Currently, our Operations people know about the issue and know that when they update the subscriber account on the IMS manually the VGW will become dergistered.  They then know that they need to manually log into the VGW and force it to reregister.  I wrote a short eem applet so they can do this with a simple cli alias command 'newreg'.  The situation leave a lot to be desired, but that's where we are today.
I am currently trying to use the Cisco IOS TCL IVR package to implement a SIP SUBSCRIBE to SIP Registration events.  I have yet to get a SUBSCRIBE to go out of the VGW.
Ok, sounds interesting..
My team and me are currently investigating in a similar thing. We would like to receive a SIP-Notify.. when we have any update that may help you I´ll provide it to you.
Torsten
I got a very basic TCL IVR application to send a Subscribe to our IMS and receive a notify.  You have to add the following to the IOS configuration:
application
 service SubscribeReg flash:SubscribeReg.tcl
  param redirect-number 8163484000
 session
  start SubscribeReg_sess1 SubscribeReg
The param statement can be used to pass data to the TCL script, in my case I want to pass the Default IMPU/userid/MainTN of the PBX.
Next you have to define a TCL script.  Below is mine, which is far from complete.  I only wanted to test whether I could send a good Subscribe that our IMS would accept.  The 'subscription open' command below is what causes IOS to send the Subscribe.  It does more than that, it waits for a response and upon a 407 resends with auth nonce, and then waits for the Notify and responds to it with a 200 OK.
# SubscribeReg.tcl
# Script Version 0.1 - 2015-5-5
# This tcl script
proc init { } {
    global param
proc Send_Subscribe { } {
    set headers(From) "sip:+18163484000@ims.eng.rr.com"
    set headers(To)   "sip:+18163484000@ims.eng.rr.com"
    set SubscrParams(protoHeaders) headers
    set SubscrParams(event) reg
    set SubscrParams(expirationTime) 1210
    set mySubID [subscription open sip:+18163484000@ims.eng.rr.com SubscrParams]
proc Check_Response { } {
    set status [infotag get evt_status]
    puts status
    if { $status != "su_000"} {
         puts "Successful Subscribe"
proc Timeout { } {
    puts "Expires Timer Expired"
proc act_Abort { } {
    puts "Unexpected event - entering act_Abort"
    call close
init
#   State Machine
  set SubscribeSM(any_state,ev_disconnected) "act_Abort,same_state"
  set SubscribeSM(SUBSCRIBING,ev_any_event) "Send_Subscribe,WAIT_FOR_RESPONSE"
  set SubscribeSM(WAIT_FOR_RESPONSE,ev_subscribe_done)  "Check_Response,NORMAL"
  set SubscribeSM(NORMAL,ev_unsubscribe_indication)   "Timeout,SUBSCRIBING"
  fsm define SubscribeSM  SUBSCRIBING
Initially, the Subscribe it generated was not accepted by IMS:
Sent:
SUBSCRIBE sip:+18163484000@172.17.254.75:5060 SIP/2.0
Via: SIP/2.0/UDP 10.40.208.29:5060;branch=z9hG4bK66D9FC4
From: sip:+18163484000@ims.eng.rr.com;tag=62230F74-1FDF
To: sip:+18163484000@ims.eng.rr.com
Call-ID: 4B452078-F40511E4-849ADB8F-ECAF76A@10.40.208.29
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: reg
Expires: 1210
Contact: <sip:10.40.208.29:5060>
Content-Length: 0
May  7 11:33:50.295 EDT: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden - User Not Registered
v:SIP/2.0/UDP 10.40.208.29:5060;branch=z9hG4bK66D9FC4
f:<sip:+18163484000@ims.eng.rr.com>;tag=62230F74-1FDF
t:<sip:+18163484000@ims.eng.rr.com>;tag=1127270911
i:4B452078-F40511E4-849ADB8F-ECAF76A@10.40.208.29
CSeq:101 SUBSCRIBE
l:0
The problem was that the Request-URI was sip:+18163484000@172.17.254.75:5060
instead of  sip:+18163484000@ims.eng.rr.com, which I put in the 'subscription open', statement.  For some reason, TCL or IOS SIP decided to do a dns lookup on the fqdn instead of just using the literal fqdn.  Fortunately, IOS did send the Subscribe message to the IP address of the SIP outbound proxy:
voice service voip
  sip
    outbound-proxy dns:eepcscf-gm.ims.eng.rr.com reuse
After talking about this with a co-worker, I remembered the 'voice class sip-profiles' commands, and put the following in to change the Request-URI:
voice class sip-profiles 100
  request SUBSCRIBE sip-header SIP-Req-URI modify "(.*)@.*" "\1@ims.eng.rr.com;user=phone SIP/2.0"
It worked!  Below is the debug ccsip messages output:
May  8 09:41:03.228 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:+18163484000@ims.eng.rr.com;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.40.208.29:5060;branch=z9hG4bK68411986
From: sip:+18163484000@ims.eng.rr.com;tag=66E22814-DA5
Call-ID: B4343033-F4BE11E4-84A6DB8F-ECAF76A@10.40.208.29
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: reg
Expires: 1210
Content-Length: 0
May  8 09:41:03.244 EDT: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
v:SIP/2.0/UDP 10.40.208.29:5060;branch=z9hG4bK68411986
f:<sip:+18163484000@ims.eng.rr.com>;tag=66E22814-DA5
t:<sip:+18163484000@ims.eng.rr.com>;tag=986239153
i:B4343033-F4BE11E4-84A6DB8F-ECAF76A@10.40.208.29
CSeq:101 SUBSCRIBE
Proxy-Authenticate:Digest realm="ims.eng.rr.com",nonce="75dddaec554cbcef111cef05ea5c403a2123215769b1379d4fb37d",qop="auth"
l:0
May  8 09:41:03.248 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.40.208.29:5060;branch=z9hG4bK68421E92
Max-Forwards: 70
Event: reg
Expires: 1210
Content-Length: 0
Proxy-Authorization: Digest username="E06F4E57B7BDC175@ims.eng.rr.com",realm="ims.eng.rr.com",uri="sip:+18163484000@172.17.254.75:5060",response="5449f4c2ca85270b40eab3e6b97600ae",nonce="75dddaec554cbcef111cef05ea5c403a2123215769b1379d4fb37d",cnonce="1F86A2C9",qop=auth,algorithm=md5,nc=00000001
CSeq: 102 SUBSCRIBE
May  8 09:41:03.272 EDT: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
v:SIP/2.0/UDP 10.40.208.29:5060;branch=z9hG4bK68421E92
t:<sip:+18163484000@ims.eng.rr.com>;tag=1254025593
CSeq:102 SUBSCRIBE
Expires:1210
m:<sip:abrscscf.ims.eng.rr.com:5090;lskpmc=S11>
Record-Route:<sip:172.17.254.170;routing_id=pcscf_a_side;lskpmc=P11;lr;serv_user=10.40.208.29:5060>
l:0
May  8 09:41:03.288 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:10.40.208.29:5060 SIP/2.0
v:SIP/2.0/TCP 172.17.254.170:5060;branch=z9hG4bKc96ca3c2c2e7da83fb9759288d008de5;lskpmc=P11
Record-Route:<sip:172.17.254.170;routing_id=pcscf_a_side;lskpmc=P11;lr>
v:SIP/2.0/TCP 172.17.254.75:5090;branch=z9hG4bK93a8447a0d8890d6e32d6205611029d1;lskpmc=S11
f:<sip:+18163484000@ims.eng.rr.com>;tag=1254025593
t:<sip:+18163484000@ims.eng.rr.com>;tag=66E22814-DA5
o:reg
Subscription-State:active
CSeq:1 NOTIFY
c:application/reginfo+xml
Max-Forwards:68
l:705
<?xml version="1.0"?><reginfo xmlns="urn:ietf:params:xml:ns:reginfo" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="0" state="full"><registration aor="sip:+18163484000@ims.eng.rr.com" id="7d94aa39111431092326854924" state="active"><contact id="111431092326854924" state="active" event="registered"><uri>sip:+18163484000@10.40.208.29:5060</uri><unknown-param name="audio"/></contact></registration><registration aor="sip:+18163484001@ims.eng.rr.com;end-num=18163484999" id="a9968911111431092326854924" state="active"><contact id="111431092326854924" state="active" event="created"><uri>sip:+18163484000@10.40.208.29:5060</uri><unknown-param name="audio"/></contact></registration></reginfo>
May  8 09:41:08.296 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 172.17.254.170:5060;branch=z9hG4bKc96ca3c2c2e7da83fb9759288d008de5;lskpmc=P11,SIP/2.0/TCP 172.17.254.75:5090;branch=z9hG4bK93a8447a0d8890d6e32d6205611029d1;lskpmc=S11
From: sip:+18163484000@ims.eng.rr.com;tag=1254025593
To: sip:+18163484000@ims.eng.rr.com;tag=66E22814-DA5
Date: Fri, 08 May 2015 13:41:08 GMT
CSeq: 1 NOTIFY
Record-Route: <sip:172.17.254.170;routing_id=pcscf_a_side;lskpmc=P11;lr>
Content-Length: 0
Wow, that look impressive, thanks for sharing it.
I guess that will give us a good starting point for our approach
Thank you for sharing! I want use the sip Notify to trigger a WSMA initiator profile. The router is behind a firewall and with this method the backend should direct triggered. Alfred is it possible inside an IVR application to execute CLI commands?
Maybe, the EEM can have a syslog event detector that looks for the sip commands. I can’t find the correct event pattern for that. Do you think that could be an approach for that?
This TCL Subscribe/Notify feature is specifically for the SIP protocol (Session Initiation Protocol, rfc3261) over UDP or TCP which is primarily used as a telephony signalling protocol to set up and tear down calls.  SIP can be used for other functions, but I don't think it is used with WSMA, which to my knowledge is SOAP/XML based.  The SIP Subscribe/Notify Feature is described in the IOS SIP 15.1 Config Guide.
However, that does not mean you can't use TCL.  I would look in the TCL applications guide for SOAP examples.  But I don't have any knowledge of them.
Yes, exactly. I tried to catch the SIP Notify Event to trigger another TCL script with wsma stuff. Another program sends the Sip Notify packet to the router and the sip message is also displayed in the log. In the state machine I look for the ev_notify event, but I am not sure if that can work. I was not able to catch that sip event. Have you any idea why it does not work?
Here my sample code:
proc act_init { } {
    set syslog [open "syslog: " w+]
    puts $syslog "init script...."
    close $syslog
proc act_Notify { } {
    set content_type [infotag get evt_proto_content_type]
    puts "\n\n\n**** Notification content_type=$content_type\n\n"
    set content [infotag get evt_proto_content]
    puts "\n\n\n**** Notification content=$content\n\n"
    puts $syslog "message notify recived...."
    close $syslog
    call close
#  State Machine
set fsm(any_state,ev_disconnected) "act_Abort same_state"
set fsm(any_state,ev_notify) "act_Notify same_state"
set fsm(INIT,ev_any_event) "act_init same_state"
fsm define fsm INIT
I have spent a little more time fleshing out my Subscribe/Notify state machine, and I was trying to use the ev_notify event to detect receipt of the Notify, but I was never able to receive it.  So I tried using ev_notify_done instead, and I was able to get the state machine to receive this event.  I have not done much else, because I have some other fires I am fighting on a different front, but I hope to get back to this in a week or two.
In my application, I want to respond to the receipt of SIP error responses, which I have been detecting via an EEM applet that monitors the SIP message counts in the router's SIP MIB.  But I have been struggling with how to communicate between the EEM applet and the Tcl IVR state machine.  It is possible to set Tcl IVR parameters from the EEM applet by executing CLI commands in config mode, so I think this will work in one direction.  I have not yet figured out how to get the TCL IVR state machine send an indication back to the EEM applet to tell it whether the router's SIP Registration is still active. But there are CLI commands to display the status of a TCL IVR state machine so I am optomistic I can find a way.
Thank you very much! I had also no success to detect the ev_notify event. I try now if i am able to catch the ev_notify_done event.
In my application, i want to use the sip notify to trigger some WSMA functions. The IVR script should write on sip notify a message into the syslog. Another EEM script detects that entry in syslog and creates a wsma initiator profile (CLI Commands). It is not an optimal solution but I found no better way to do it..
