AS5300 with Nortel Meridian 11C and Lucent Definity
jmoraes
I have the following environment:
MERIDIAN--R2DIGITAL--AS5300--IP--AS5300--R2DIGITAL--DEFINITY
When I post voice connections from Meridian to Definity all work's fine, but in reverse way the phone ring one time and the call is cleared.
Others H.323 terminals (IP Phones, Softphones, etc.) placa calls to all gateways without problems ?
Anyone have any idea about to fix this problem ?
Thank's in advance
Hello.
Compare two debugs ( Meridian --> Lucent )
another call ( Lucent --> Meridian )
and find difference.
GW is transparent in this situation, so culprit
is Meridian.
Thank's for your reply.
There is other information about this problem. When connections flow from phone connected on Definity to Meridian the phone connected on Meridian ring one time and call is dropped. But when AS5300 connected to Definity start a connection through "csim start xxxx" the phone on Meridian side ring many times and when the call is answered the call don't drop.
In your opinion wich debug better detect this problem ?
Well,
On the GW connected to the Definity collect
Debug isdn q931 and debug h225 q931.
and simultaneous debug isdn q931 on GW connected to the
Meridian.
I suppose that Lucent and Meridian have different value
of one of the many :) timers. Check in the GW
configuration existence of
sevice timestamp ...... debug
