11-23-2010 05:39 AM
Dear All,
Is there any way to run Voice Gateway like AS5400 with two protocol H323 and SIP simultaneously? Any voice gateway performance afftected? or Voice quality affected? if we run both protocol in only one gateway?
Best Regards,
Daneth
Solved! Go to Solution.
11-23-2010 11:49 AM
AS5400 supports H.323 and SIP dial-peer at the same time without problems.
I've used AS5400 in IP2IP gateway mode to convert SIP in H.323 and vice versa with about 150 concurrent calls.
In lab I also tested SIP, H.323 and MGCP at same time.
In default configuration SIP and H.323 are both active.
AS5400 uses H.323 like default signalling protocol. Is sufficient create a voip dial-peer. To specify SIP you must use the command "session protocol sipv2" under a dial-peer.
To shut down SIP use
voice service voip
sip
call service stop
To shut down H.323 use
no gateway
11-23-2010 11:49 AM
voice service voip
sip
call service stop
no gateway
11-23-2010 06:22 PM
Hi Giordano,
Thanks for your answer.
Daneth
