Caller-ID Enable Not Working
woodjl1650
I have a Cisco 3740 with CME 8 and NM-2 2 FXO 2 FXS ports.  I want to enable caller-id on the rouer, but when I issue for caller-id enable command under the FXO port the router tells me that command is invalid.  I don't really know where is issue is or how to solve it.  Is there something wrong with my config or are some FXO not able to support the caller-id command?  Below if my current config:
CallManager#show run
Building configuration...
Current configuration : 6376 bytes
version 12.4
hostname CallManager
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp pool VOICE/DATA
   network 10.0.50.0 255.255.255.0
   option 150 ip 10.0.50.1
   default-router 10.0.50.1
trunk group  OUT
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
voice class cause-code 1
no-circuit
voice translation-rule 1
rule 1 /^702586\(1...\)$/ /\1/
voice translation-profile DID
translate called 1
crypto pki trustpoint TP-self-signed-2215009052
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2215009052
revocation-check none
rsakeypair TP-self-signed-2215009052
crypto pki certificate chain TP-self-signed-2215009052
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32323135 30303930 3532301E 170D3133 30333233 30303331
  35375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 32313530
  30393035 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B100 E333437B 44D0EC60 8FADE1A0 89D3ADBC CDE13BD5 623B5205 75493AFB
  C0D8BF0F 8D9129F1 5DE54189 C182498F 531FE400 AEA816C6 F6A7FCF0 447636BB
  79B90C31 51B2879A 84489D5D 889DA761 835E8501 C9D86C3F 453214A2 A8EEA53C
  C0244A31 703DA1F7 CA61AAAE A9BD3AED A1910AB4 98F24607 18208372 6E12F2B1
  85450203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
  551D1104 0F300D82 0B43616C 6C4D616E 61676572 301F0603 551D2304 18301680
  14490111 E89DCDAD EBB061C6 84597CC0 58E8CFCE 30301D06 03551D0E 04160414
  490111E8 9DCDADEB B061C684 597CC058 E8CFCE30 300D0609 2A864886 F70D0101
  04050003 81810083 6DE219E4 6ADFC6CE 3EFDF216 E6475678 77FF92DC FDA75912
  4E81FBAE 162EEEE8 15A477F2 3AB505F0 3C393BF8 C4CEACDD 0829CFC9 FC5327B7
  CC0797CE BD2A6A4C E5F4C806 57BA4817 A58DEB7B FB69DA83 46C26E64 19BA57B2
  3A8B378C 23ABC19F E55D35DA 3B914D26 41FBEA3F 73226D58 B87B5AEC 75A5E585
  FA1B6B93 69B97D
        quit
username woodjl password 0 henry999 privilege 15
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.0.50.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
no fair-queue
interface Serial0/0.31 point-to-point
ip address 10.1.12.3 255.255.255.0
snmp trap link-status
frame-relay interface-dlci 301
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip http path flash:gui
tftp-server flash:P00308000400.bin
tftp-server flash:P00308000400.loads
tftp-server flash:P00308000400.sb2
tftp-server flash:P00308000400.sbn
control-plane
voice-port 1/0/0
ring cadence pattern01
cptone GB
voice-port 1/0/1
voice-port 1/1/0
trunk-group OUT
no battery-reversal
cptone GB
connection plar opx 1001
description Office Line
voice-port 1/1/1
no battery-reversal
cptone GB
connection plar opx 1002
description Home Line
dial-peer voice 1001 pots
trunkgroup OUT
description Long Distance
forward-digits all
dial-peer voice 1002 pots
trunkgroup OUT
description Local Calls
destination-pattern .T
forward-digits 7
dial-peer voice 1003 pots
description International
destination-pattern 011T
port 1/1/1
dial-peer voice 1004 pots
incoming called-number .
direct-inward-dial
dial-peer voice 200 voip
destination-pattern 1...
session target ipv4:10.0.50.1
dial-peer voice 1 pots
preference 1
destination-pattern 91..........
port 1/1/1
forward-digits 11
dial-peer voice 4 pots
destination-pattern 9[2-9]......
port 1/1/1
forward-digits 7
dial-peer voice 3 pots
port 1/1/1
forward-digits 7
dial-peer voice 4444 pots
translation-profile incoming DID
direct-inward-dial
dial-peer voice 2001 voip
destination-pattern 1001
codec g711ulaw
dial-peer voice 2002 voip
destination-pattern 1002
codec g711ulaw
gatekeeper
shutdown
telephony-service
load 7960-7940 P00308000400
max-ephones 24
max-dn 48
ip source-address 10.0.50.1 port 2000
timeouts interdigit 2
max-conferences 4 gain -6
web admin system name admin secret 5 $1$wMrx$WGyz/gL0UlSrWOhB6IBuz0
dn-webedit
time-webedit
transfer-system full-consult
directory entry 1 702778XXXX name Home
directory entry 2 913758XXXX name Steve & Teresa Wood Home
directory entry 3 913683XXXX name Teresa Wood Cell
directory entry 4 913683XXXX name Steve Wood Cell
create cnf-files version-stamp 7960 Mar 23 2013 00:14:46
ephone-dn  1
number 1001
label Lab
description Lab
name Lab
hold-alert 30 originator
ephone-dn  2
number 1002
label Office
description Office
name Office
ephone  1
device-security-mode none
mac-address 0013.80DF.7F34
speed-dial 1 702401XXXX label "Jonathan Cell"
speed-dial 2 702401XXXX label "Katie Cell"
speed-dial 3 702404XXXX label "Ops Desk"
type 7960
button  1:1
ephone  2
mac-address 0011.20BA.F7B8
type 7960
button  1:2
ephone-hunt 1 peer
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
login
ntp server 64.209.210.20
end
Jorge Armijo
Level 4
Level 4
So you can't enter "caller-id enable" on the voice-ports?
Did you try removing the CPTone?
Give it a try and let us know.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
paolo bevilacqua
Likely you are using very, very old FXO card with no caller ID support.
