Can I connect a 2900XL switch to Cisco 7960 pc port?
Yang Xia
It doesn't seem to be working. I tried access vlan as well as trunking config on the 2900XL switch port to a 7960 phone PC port.
Try disabling spanning tree.
6 Replies 6
paolo bevilacqua
Should work. But why don't you connect it upstream of the phone then.
It's a temporary switch and I don't want to mess around the phone upstream connection. Also I can power on/off the 2900 switch without affecting the phone. What should I configure the switch port to 7960 pc port? I've tried both access and trunk mode.
Access. Check, it may get blocked by bpduguard or other security feature.
Access doesn't work. Switch is getting the bpdu packet from the phone pc port.
interface FastEthernet0/1
switchport access vlan 231
end
00:02:03: %SPANTREE-2-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0/1 on vlan 231.
00:02:03: %SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/1 on vlan 231. Inconsistent port type.
Changed to trunk port still doesn't help. Switch thinks it's the root for both VLANs.
switchport mode trunk
end
#sh spanning-tree brief
VLAN1
Spanning tree enabled protocol IEEE
ROOT ID Priority 32768
Address 0001.968f.94c0
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32768
Port Designated
Name Port ID Prio Cost Sts Cost Bridge ID Port ID
Fa0/1 128.13 128 19 FWD 0 0001.968f.94c0 128.13
Fa0/4 128.16 128 19 BLK 0 0001.968f.94c0 128.16
Fa0/5 128.17 128 19 BLK 0 0001.968f.94c0 128.17
Fa0/6 128.18 128 19 BLK 0 0001.968f.94c0 128.18
Fa0/7 128.19 128 19 BLK 0 0001.968f.94c0 128.19
Fa0/8 128.20 128 19 BLK 0 0001.968f.94c0 128.20
Fa0/10 128.23 128 19 BLK 0 0001.968f.94c0 128.23
Fa0/11 128.24 128 19 BLK 0 0001.968f.94c0 128.24
Fa0/12 128.25 128 19 BLK 0 0001.968f.94c0 128.25
Fa0/13 128.26 128 19 BLK 0 0001.968f.94c0 128.26
Port Designated
Fa0/14 128.27 128 19 BLK 0 0001.968f.94c0 128.27
Fa0/15 128.28 128 19 BLK 0 0001.968f.94c0 128.28
Fa0/16 128.29 128 19 BLK 0 0001.968f.94c0 128.29
Fa0/17 128.31 128 19 BLK 0 0001.968f.94c0 128.31
Fa0/18 128.32 128 19 BLK 0 0001.968f.94c0 128.32
Fa0/19 128.33 128 19 BLK 0 0001.968f.94c0 128.33
Fa0/20 128.34 128 19 BLK 0 0001.968f.94c0 128.34
Fa0/21 128.35 128 19 BLK 0 0001.968f.94c0 128.35
Fa0/22 128.36 128 19 BLK 0 0001.968f.94c0 128.36
Fa0/23 128.37 128 19 BLK 0 0001.968f.94c0 128.37
Fa0/24 128.38 128 19 BLK 0 0001.968f.94c0 128.38
VLAN231
Address 0001.968f.94c1
Port Designated
Fa0/1 128.13 128 19 FWD 0 0001.968f.94c1 128.13
Fa0/2 128.14 128 19 FWD 0 0001.968f.94c1 128.14
Fa0/3 128.15 128 19 BLK 0 0001.968f.94c1 128.15
Fa0/9 128.22 128 19 FWD 0 0001.968f.94c1 128.22
That takes care of the issue. Thanks for the tip!
