Can I use AS5350 for Sip to Sip gateway with transcoding
ross.millan
I have an issue where we need to transcode g711ulaw to g711alaw between voip providers using SIP
I would like to know if it is possible to use an AS5350 for such a task?
Any links or references to what I would need to do in the configuration would also be greatly appreciated.
Marwan ALshawi
i am not sure if u have DSPs for this !
kzeeshan
Yes, this can be done by using AS5350 as CUBE.
Please go through the documentation:
Make sure below is configured with proper dial-peers.
voice service voip
allow-connections sip to sip
dial-peer voice 100 voip
incoming called-number 919.......
codec transparent
dial-peer voice 200 voip
destination-pattern 919........
codec g711alaw
Below is for your reference.
Cisco UBE on Cisco.com
http://www.cisco.com/go/cube
Cisco CommunicationsTransformations Whitepapers
http://www.cisco.com/go/cube(section of Whitepapers)
Customer Case Studies
Cisco Networkers Presentations
SIP Trunks for PSTN
CUBE Designs
Cisco UBE PBX Interoperability Reports (Avaya / Nortel)
http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805bd13d.html
