Cisco 2821 Router with dsp errors
Hi experts.
I have a Cisco 2821 Router showing the following errors:
012329: Feb 13 16:40:38: mbrd_e1t1_vic_connect: setup failed
012330: Feb 13 16:40:38: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/5)
012331: Feb 14 09:18:32: mbrd_e1t1_vic_connect: setup failed
012332: Feb 14 09:18:32: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/0)
012333: Feb 14 09:27:59: mbrd_e1t1_vic_connect: setup failed
012334: Feb 14 09:27:59: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/0)
012335: Feb 14 09:28:32: mbrd_e1t1_vic_connect: setup failed
012336: Feb 14 09:28:32: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/0)
012337: Feb 14 09:28:33: mbrd_e1t1_vic_connect: setup failed
012338: Feb 14 09:28:33: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/1)
012339: Feb 14 09:30:39: mbrd_e1t1_vic_connect: setup failed
012340: Feb 14 09:30:39: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/0)
012341: Feb 14 09:35:34: mbrd_e1t1_vic_connect: setup failed
012342: Feb 14 09:35:34: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/3)
012343: Feb 14 09:40:34: mbrd_e1t1_vic_connect: setup failed
012344: Feb 14 09:40:34: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/1)
Also, in the Show Controllers E1 appears 104 slip secs and 104 errored secs.
The IOS version of the router is
(C2800NM-ADVIPSERVICESK9-M), Version 12.4(3h)
What can i do to resolve this issue?
Thanks a lot
paolo bevilacqua
1. urgently update ios
2. configure network-clock-select for the E1.
